Email problem
May 05, 2009 6:01am
  • #1 / May 05, 2009 6:01am
    Renman
    Moderator’s note: Subject translated into English.
    Is er iemand in die het in NL kan uitleggen?
    ik zit met het volgende probleem, ik gebruik de Mailing List module, alles werkt goed kan email versturen. Dit gebeurd via SMTP, Email karakter Encoding staat aan en geeft de volgende fout:
    Fout
    Niet mogelijk om email te versturen op dit tijdstip.
    Debugging Message
    to: 553 5.1.2 ... Domain xxxxxxx.nl does not exist
    Failed to Send Command. Error: 553 5.1.2 ... Domain xxxxxxx.nl does not exist
    data: 503 5.0.0 Need RCPT (recipient)
    Failed to Send Command. Error: 503 5.0.0 Need RCPT (recipient)
    500 5.5.1 Command unrecognized: "User-Agent: ExpressionEngine 1.6.4"
    Failed to send SMTP email. Error: 500 5.5.1 Command unrecognized: "User-Agent: ExpressionEngine 1.6.4"
    Unable to send email using SMTP
    Zitten er in de email adressen typefouten of is dit iets anders?
    Hij geeft de volgende fouten weer 553, 503 en 500.
    Groetjes Renman
  • #2 / May 05, 2009 6:23am
    Renman, may I ask you to please keep your postings in English? While we do have quite a few Dutch users and understand that English is not the native language of all our users, our support, and by extension this forum, are still in English only. As to your issue, it looks like you are sending mail to a non-existent domain
    If you are sure that the domain does exist (because you can reach it via HTTP, eg.) it might be a lookup issue, ie your server does not have access to a properly configured DNS server.
    Also, you seem to be using EE 1.6.4. An upgrade to 1.6.7 at your earliest convenience is advised if only for security reasons.
