I have moved the site to a new server (using the wiki entry as a guide), database transfered and everything on the frontend working fine…
But the login to the control panel does not work…
Any ideas?
Thank you for your help…
May 04, 2009 5:49am
Subscribe [3]#1 / May 04, 2009 5:49am
Any ideas?
#2 / May 04, 2009 6:25am
When you say doesn’t work, what do you mean? Do you get an error message?
#3 / May 04, 2009 6:37am
at http://preclinics.larsschulz.info/cms/
As you can see the styling of the login screen is broken too, so this might be a path issue. I have updated all the config data though…
If I try to login with the login information working on the testing server, the login just refreshes…
Thank you for your quick reply.
Lars
#4 / May 04, 2009 8:11am
sorry to bother, but do you have any suggestions?
#5 / May 04, 2009 8:59am
meerestier, I can tell from your username and the fact that you are using the German language pack that you are situated in Europe. The majority of our support specialists, however, is not: some overnight and weekend coverage not withstanding, we provide support mainly during North American business hours. Thank your for your patience.
That said, take a look at this article, see if it helps.
