Get EE to show archives as per ...
April 28, 2009 6:02am
  • #1 / Apr 28, 2009 6:02am
    shahW
    Greetings fellow EE-ians ,
    I have a couple of question today, just wondering if you guys could point me to the right direction 😊
    FYI - I only have the EE core v1.6.7. And definitely will be upgrading to personal / commercial as soon as I’m off the training wheels.
    Q #1 - I’m looking for a way for EE to return me weblog archives in the following scenario. Let’s say I have 10 entries in 2009, 20 entries in 2008 and XX entries in 2007 so forth. How do I get EE to return the year *once* only as per example below
    2009       19 Mar      Entry title 5        Excerpt    commentNumber
               13 Mar      Entry title 4        Excerpt    commentNumber
               10 Feb      Entry title 3        Excerpt    commentNumber
                3 Jan      Entry title 2        Excerpt    commentNumber
    2008       19 Mar      Entry title 5        Excerpt    commentNumber
    2007       19 Mar      Entry title 5        Excerpt    commentNumber
    Q #2 - How can I retrieve no. of comments for each entry?
    ExpressionEngine newbie here, please pardon for not knowing exactly the terms I should be searching for on the forum.
    Thanks in Advance
    -sw
  • #2 / Apr 28, 2009 9:06am
    Boyink!
    This plugin might do the trick.
  • #3 / Apr 28, 2009 9:46am
    shahW
    Hi Mike,
    Thanks for the plugin info.😊
    Do you or anybody else happen to know the answer for Question 2?
    thanks
  • #4 / Apr 28, 2009 9:56am
    Have you considered using {comment_total}? Otherwise, a custom query might be the easiest way.
  • #5 / Apr 28, 2009 11:29am
    shahW
    Ingmar,
    yes I did. However, it does not work with {exp:weblog:category_archive}. Or maybe I could just do away with it. I need to play more with EE.
    -sw
  • #6 / Apr 28, 2009 12:03pm
    No, it does not, it’s available only in exp:weblog:entries. So, I suggest a custom query using COUNT. Shouldn’t be too difficult.
  • #7 / Apr 28, 2009 9:57pm
    shahW
    Isn’t the Query module only available on Personal/Commercial EE? Currently, I’m only using the core.
  • #8 / Apr 29, 2009 2:13am
    That’s right, the query module is not available in EE Core, so you’d probably have to use some PHP.
  • #9 / May 26, 2009 11:30am
    shahW
    Would someone help me with the question below? I’ve tried playing with exp:query unfortunately I’m not much of a programmer.
    Thanks in Advance
    -sw[/quote]
