Hi!
I have my members area running successfully through ssl. That ssl area is a masked secure subdomain as mentioned above. When members login the ‘you are now logged in message comes up’ it goes to the right page but the {if} conditionals do not show that they are logged in.
If you loggout from here it says you are logged out but you can go right back in as the page is always open for business….
Any redirects if logged out do not work if they go to that page directly WITHOUT logging in.
I tested this in another Masked SubDomain (Non SSL) and everything works as it should with the conditionals and redirects. It is something with the subdomain being in the SSL folder. (Yahoo Hosting - they make you use there SSL folder)
I have searched and tried a bunch of the things people have recommended but cannot get anywhere….
Kyle
