Adding rate system
March 19, 2009 2:39pm
Subscribe [6]
  • #1 / Mar 19, 2009 2:39pm
    Waiel
    I’m trying to figure out this.
    in the web-log how can i add ratting system to each entry of the weblog so members can rate the article ?
    is it in the system or in an external Add-on/plug-in that i have to get .
    appreciate any help
  • #2 / Mar 19, 2009 3:07pm
    LynneL
    It’s not free, but there’s the Solspace Ratings module.
  • #3 / Mar 19, 2009 3:25pm
    Waiel
    Thanks LynneL, 😊
    will check it out ^_^
  • #4 / Mar 19, 2009 4:05pm
    Justin Long
    There are also a lot of nice jQuery plugins that allow rating systems depending on exactly what you are looking for
  • #5 / Mar 19, 2009 4:13pm
    Waiel
    thanks Justin,
    Solspace Ratings module is exactly what i was looking for ..
    and i have got it already 😊
  • #6 / Apr 18, 2009 4:07pm
    macpro
    Wich jQ plugins are you talking about? I’m looking for an easy mouse-over JS-styled rating, not a “drop-down, select and press submit” method.
    Cheers
  • #7 / Apr 20, 2009 1:26pm
    ender
    using solspace’s rating module I rolled my own jQuery “mouse-over-the-stars-and-click” rating functions.  it’s not too bad if you can handle writing the javascript… solspace pretty much designed the plugin around being able to do that.
  • #8 / Aug 04, 2009 9:50am
    jasonjulien
    Hey Ender, any chance you’d be willing to share your “mouse-over-the-starts-and-click” goodness?
  • #9 / Aug 04, 2009 10:10am
    ender
  • #10 / Nov 02, 2009 11:01pm
    Chris Arnold
    Bringing this back up — is there a rating tool that can be used without having to be a member? In other words, rate an article without being logged in, and perhaps tracked with an IP address to prevent someone sitting there rating it up or down? Then, on top of that, sort results by highest rated?
    I know there are jQuery star ratings out there, but none of them discuss EE or database integration specifically.
