I have a site that will use a multilevel suckerfish type navigation. The nav looks sort of like this:
1st level link
• 2nd level link
• • 3rd level link
• • 3rd level link
etc.
etc.
...you get the idea. I have two problems:
1.The client wants to be able to switch the order of the 1st level links, so that “Home | About | Store” could be switched to “About | Home | Store.”
2. The client wants the 1st level links (that open the submenus on hover) to also be linked to entries.
My first thought was to use a single weblog and parent and child categories, because it’s easy to change the order of categories. How do I make the 1st level link go to a particular entry, though? Is there a better way to organise this?
I’m worn out from working and need your help! Thanks.
