search:custom_field in dynamic parameters?
February 23, 2009 11:24am
  • #1 / Feb 23, 2009 11:24am
    Brent Cartier
    In the docs for dynamic weblog parameters is says “Every Parameter available to the weblog tag can be set dynamically”. I’m trying to set the ‘search:assigned’ parameter as a dynamic parameter, but I’m running into problems.  I’m using a form element with a name of ‘search:assigned’ and I’ve added ‘search:assigned’ to the parameter of the entries tag (dynamic_parameters=“status|search:assigned|category”)
    I’ve tried tested whether the POST info is there using an php echo statement, but I get no results from the weblog entries tag.
    In theory, should this work?
    EE 1.6.6 Build 20081212
    PHP5, MySQL 5
  • #2 / Feb 23, 2009 12:19pm
    Hi, Brent. Can you post the exact code you’re attempting to use? A link to the site would be helpful too.
