trackback url tag not displaying in prod.
February 20, 2009 5:05pm
  • #1 / Feb 20, 2009 5:05pm
    tsoares
    I have the following code in http://dev-blogs.cisco.com/ciscotalk/ar/global/_entries is showing up the trackback urls.
    <h3 class="title">Post a trackback</h3>
            <div class="post">
                    Ping this URL to post a trackback:
                    {exp:trackback:url}
            </div>
    I worked on adding the codes in bits to the global/_entries template and I was able to fix the issue only on http://dev-blogs.cisco.com as per “http://ellislab.com/forums/viewreply/535160/”
    The same code not working on http://blogs.cisco.com/ciscotalk/ar/, but I see the trackback ping url in the <rdf></rdf> code. Both sites are site up exactly same.
    Could I modify the Current mcp.trackback.php and extract track backurl function.
    Pls let me know how to debug this issue. Pls tell me if there any other alternatives for this. Any suggestions will be appreciated.
    Mod Edit: Moved to the Technical Support Forum (5/29/2009)
  • #2 / Feb 20, 2009 9:23pm
    tsoares
    Could some one from EE suppport look in to this issue as this one of the valuable feature to bloggers.
    The http://blogs.cisco.com/ciscotalk is created using Mutlisite Module.
    I have the following piece of code in a template:
    <a href="http://blogs.cisco.com/ciscotalk/vis_trackback_test/index">http://blogs.cisco.com/ciscotalk/vis_trackback_test/index</a>
    <h4>Trackback Test</h4>
    <p>                    {exp:weblog:entries weblog="ar" limit="1"}<br />
                           <a href="http://{url_title_path=ar/index}">{title}</a></p>
    <p>                       <br />
                        {/exp:weblog:entries}</p>
    <h2>Trackback URL:</h2>
    <p>{exp:trackback:url}
    The trackback url does not show up on http://blogs.cisco.com/ciscotalk/vis_trackback_test/index
  • #3 / May 29, 2009 4:19pm
    tsoares
    Hello,
    Is any one in this community having the same issue as explained above?
  • #4 / Jun 01, 2009 4:29pm
    tsoares, can you please clarify which problems you are experiencing? What version and build of EE are you using? Do you’ve got a link?
  • #5 / Jun 02, 2009 10:03pm
    tsoares
    Hi Ingmar,
    The version of ExpressionEngine is 1.6.6 and Build:  20081212. The issue is Trackback ping url is showing up as blank(not displaying at all) in production environment blogs that were built using the Multisite module and it is working fine in dev environment. I used the code snippet that was mentioned in 1st post of the issue.
    I have done all different types of debugging as per my knowledge and it would be highly appreciated if you could help on fixing this issue.
    I will post the all the debugging that I have done for looking in to this issue.
  • #6 / Jun 03, 2009 5:02am
    I would recommend to update to the latest version and build, which is 1.6.7 20090515. It’s a recommended security update. That said, if it works on one server and not the other, there are probably some differences in the setup. Anything you can put your finger on? Are you using the exact same code?
  • #7 / Jun 08, 2009 9:58pm
    tsoares
    Hi Ingmar,
    The dev site was set up under the prod root director. The prod and dev are on same server.
    I have checked all the code under dev and prod sites & directories are same.
    Could you pls tell me how can I debug why same piece of code with Multisite Module is not working.
  • #8 / Jun 09, 2009 2:35am
    VishnuP ,
    As in previous thread, trackbacks do show up as long as you view that template as a single entry page
    http://blogs.cisco.com/ciscotalk/vis_trackback_test/together_we_lead—_2009_cisco_partner_summit/
  • #9 / Jun 09, 2009 8:14pm
    tsoares
    Thanks John,
    I see that when segment_2 =“entryname” on a single entry page the trackback url is showing up.
    Pls tell me what could casue the trackback ping url not display when segment_2 = “comments” on single entry page.
    For example the trackback ping url was not rendering/displaying on : http://blogs.cisco.com/ciscotalk/ar/comments/cisco_partner_summit_takes_off_today/#comments
    Thanks Again
  • #10 / Jun 09, 2009 9:00pm
    Greg Aker
    can you explain your URL structure here?  is ‘ciscotalk’ a template group or a renamed index.php?
  • #11 / Jun 10, 2009 12:01am
    tsoares
    Hi Greg,
    http://blogs.cisco.com/ciscotalk/ is a site created using the multisite module.
    ar is the blogname.
    There is a one index.php under ciscotalk directory.
    Pls let me know if you like me to explain any more details.
  • #12 / Jun 10, 2009 2:54am
    What you got going on in your htaccess?
  • #13 / Jun 12, 2009 10:05pm
    tsoares
    Hi John,
    .htaccess has the following:
    RewriteEngine On
    RewriteRule ^(.*)$ /ciscotalk/index.php/$1 [L]
    As I mentioned earlier dev site and prod site hosted on the same server.
    Pls let me know what steps we could take to fix this issue. I have enabeled all different debugging options and those did not help to fix this issue.  We will appreciate if you could tell more steps to debug intensively to fix this issue.
    Thx!
  • #14 / Jun 14, 2009 3:31pm
    Greg Aker
    what does your code look like where the trackback URL is not showing up?  I can’t tell where it should be here:  http://blogs.cisco.com/ciscotalk/ar/comments/cisco_partner_summit_takes_off_today/
    -greg
  • #15 / Jun 14, 2009 5:54pm
    tsoares
    Hi Greg,
    I have been asked to disable track back ping url the code. So I commented out the code, here is the commented code.
            <div class="post">
                    {exp:trackback:url}
            </div>
    The Post a trackback section is supposed to be displayed as shown at url:
    http://blogs.cisco.com/news/comments/saudi_bloggers_share_life_experience_with_orphans_over_cisco_telepresence/#comments
    Pls let me know would you be able to understand the issue that I mentioned & share more debugging tips for fixing this issue.
