I am using SMTP because my host has locked down Sendmail (seems they were hacked a few months ago and have decided to make it difficult for urchins trying anonymous spamming which I am fine with). I have tested my serveraddress/user/password by adding them to outlook. I can send e-mail that way with pop3 or IMAP no problem. When I try and use SMTP in EE and use the same credentials in debugg mode I get:
Debugging Message
Unable to open SMTP socket. Error Number: 111 Error Msg: Connection refused
Unable to send data: AUTH LOGIN
Failed to send AUTH LOGIN command. Error:
Unable to send data: MAIL FROM:
Failed to Send Command. Error:
Unable to send data: RCPT TO:
to:
Unable to send data: DATA
data:
Unable to send data: User-Agent: ExpressionEngine 1.6.6 Date: Wed, 18 Feb 2009 11:11:54 -0600 From: "Test E-mail Sender" Return-Path: To: .(JavaScript must be enabled to view this email address) Subject: =?utf-8?Q?Test_e-mail_send_via_ExpressionEngine?= Reply-To: "[email protected]" X-Sender: .(JavaScript must be enabled to view this email address) X-Mailer: ExpressionEngine 1.6.6 X-Priority: 3 (Normal) Message-ID: <[email protected]> Mime-Version: 1.0 Content-Type: text/plain; charset=utf-8 Content-Transfer-Encoding: 8bit Test e-mail send via ExpressionEngine Test e-mail send via ExpressionEngineTest e-mail send via ExpressionEngineTest e-mail send via ExpressionEngine Test e-mail send via ExpressionEngineTest e-mail send via ExpressionEngineTest e-mail send via ExpressionEngine Test e-mail send via ExpressionEngineTest e-mail send via ExpressionEngine Test e-mail send via ExpressionEngine Test e-mail send via ExpressionEngine
Unable to send data: .
Failed to send SMTP email. Error:
Unable to send email using SMTPAm I looking at a authentication error or a problem with communicating with SMTP server?
