Almost there...just need help limiting number of queries
February 13, 2009 12:39pm
  • #1 / Feb 13, 2009 12:39pm
    stephlivsey
    Hi.
    I am using a SQL query to display information from my database.  Everything is working fine; however, I can’t find a way to limit the entries displayed to those submitted in just the last month.
    I tried to use the weblog display_by=“week” limit=“4” code, but that doesn’t work.  Here’s my current query; any help would be appreciated!!
    {exp:query sql="SELECT exp_freeform_entries.tribute, exp_freeform_entries.type, exp_freeform_entries.text, exp_freeform_attachments.filename, exp_freeform_attachments.extension FROM exp_freeform_entries, exp_freeform_attachments WHERE exp_freeform_entries.entry_id = exp_freeform_attachments.entry_id ORDER BY exp_freeform_entries.entry_date DESC"}
    <h5>{type} {tribute}</h5>
    <blockquote><p>{text}<br />
    <a href="http://sabarfoundation.org/SABF/images/freeform/{filename}{extension}">http://sabarfoundation.org/SABF/images/freeform/{filename}{extension}</a></p>
    </blockquote>
    <p>{/exp:query}
  • #2 / Feb 13, 2009 12:54pm
    ender
    there’s a million and one ways to write the SQL for such a thing, but knowing that EE stores everything as unix timestamps (unrelated: why not use mysql datetime fields for this?) adding something like this to your query should work:
    exp_freform_entries.entry_date > UNIX_TIMESTAMP()-2592000
    2592000 = 60*60*24*30 = 30 days worth of unix time.
  • #3 / Feb 13, 2009 1:06pm
    stephlivsey
    oooh, I think that will work.  I just put the extra line into my query like this:
    WHERE exp_freeform_entries.entry_id<>exp_freeform_attachments.entry_id AND exp_freeform_entries.entry_date > UNIX_TIMESTAMP()-172800
    Nothing has been removed (which it shouldn’t yet); but, if I did my calculations correctly, my entries should be deleted after 2 days 60*60*24*2
    Hope I did that correct; I’ll post in two days to see if this worked. Then, I’ll edit my code again to remove the entries after 30 days.
    THANK YOU!!
  • #4 / Feb 16, 2009 10:41am
    stephlivsey
    Just wanted to post a quick update:  This worked PERFECTLY!!! Thank you 😊
  • #5 / Feb 16, 2009 11:00am
    ender
    no problem, glad to help.
