Odd Parse Error
February 12, 2009 2:41pm
  • #1 / Feb 12, 2009 2:41pm
    mikeO
    I have a number of entries that are giving me a Parse error, however there is nothing different from these entries compared to entries that are working. I can’t for the life of me figure out what is wrong. Deleting the entry and creating a new one does not solve the problem.
    I am working with an EE developer as well, who cannot see anything wrong with the data for these entries, either.
    Here is the error:
    Parse error: syntax error, unexpected T_STRING in C:\xampp\htdocs\system\core\core.functions.php(637) : eval()‘d code on line 39
    Here is an example page:
    http://www.dykeman.net/architecture-projects/education/holy-rosary-parish/
    Here is a page that works, and is built in exactly the same manner:
    http://www.dykeman.net/architecture-projects/education/cascade-high-school/
    Thank you for any bright ideas,
    Mike O.
  • #2 / Feb 12, 2009 4:07pm
    What version and build of EE are you on? A build update might be a good idea, if only to rule out some corrupted files.
  • #3 / Feb 12, 2009 4:09pm
    mikeO
    1.6.4 - but our EE developer is helping us upgrade over the weekend (in hopes of fixing it)...
  • #4 / Feb 12, 2009 4:19pm
    Yes, I would definitely suggest an upgrade. If that doesn’t fix it, we’d start with a reduction template, using minimal code and adding to it until it breaks.
  • #5 / Feb 12, 2009 10:18pm
    As a note, T_STRING errors are normally errors in conditional logic in the template.  I’d definitely go with Ingmar on this, and start some major reduction testing, then building up until you find the culprit.
