I need to rewrite the URL to “lowercase” (and some more rewriting).
This is not possible in .htaccess.
Is there a hook to break in the URL handling?
http://www.example.com/This-IS-a-TeST-62843/
Has to become:
February 12, 2009 9:36am
Subscribe [4]#1 / Feb 12, 2009 9:36am
Has to become:
#2 / Feb 13, 2009 5:56pm
If it’s just when new entries are published? Then yes, a hook would be the way to go. If you’re only publishing via the cp (as opposed to moblog, api, etc) then I’d use a hook in system/cp/cp.publish.php to grab the url title before data entry and rewrite/write it.
If you’re talking about existing urls… I personally would just go through the db and change the url_title in exp_weblog_titles to be lower case. But I’d be sure I had a backup first.
#3 / Feb 16, 2009 6:16am
Unfortunately its neither, its about keeping
old links alive :-(
#4 / Feb 16, 2009 1:17pm
#5 / Feb 16, 2009 3:32pm
Yes, it matters unless the server takes special steps. Or, of course, you are using Windows servers which are not case sensitive, as a rule. Ask your host about mod_speling (sic!).
There might be other options, too.
#6 / Feb 16, 2009 3:45pm
Unscientific test, of course, but I couldn’t find one in 20 servers that had a problem converting case, including EE. But there are some, and apparently quite a few issues, according to this and this and this.
All kinds of potential problems and all kinds of solutions. It pays to make sure the host you use can handle common sense configurations as well as more esoteric needs.
#7 / Feb 17, 2009 4:28am
Case problem fixed, now for the last part, still need
some kinda URL handling hook/hack.
http://www.example.com/this-is-a-test-62843/
Has to become:
#8 / Apr 15, 2009 4:36pm
I’m in a similar situation and my host isn’t going to allow me to make the necessary edits to allow for forcing lowercase URLs via mod_rewrite. Is there a way in EE to force the URLs to lowercase before they’re routed through the system?
