How To Show Element Only At Certain Times
February 06, 2009 4:20pm
  • #1 / Feb 06, 2009 4:20pm
    454 Creative
    I have a feeling this will have a simple solution… but i just don’t know it!
    My client will have live video on their website at certain times:
    Saturday at 5pm, Sunday at 9:00am and 10:30am
    I would like to have an image show up on the homepage, but only at those times… say on Saturday from 5-6pm, and Sunday from 9-11am.
    Is there a method or extension that would let me do something like this?
    Thanks in advance.
  • #2 / Feb 07, 2009 3:49pm
    454 Creative
    I guess I could make a weblog for it, then place the image in an entry and set it as a reoccurring event with repeet…
    But it seems like there should be an easier way.
    Is it possible to use conditional statements with current_time?
    like: {if current_time > 5:00}IMAGE{/if}
  • #3 / Feb 07, 2009 7:12pm
    Kris Khaira
    You might want to check out the Repeet plugin. I think this post on SitePoint is also related to your question: Finding current show in recurring schedule w/PHP and MySQL.
  • #4 / Feb 09, 2009 5:41pm
    454 Creative
    Thanks Kris… I installed Repeet…. but couldnt get it to do what I wanted.
    Instead, I did a little more creative thinking and came up with this:
    {if ('{current_time format="%w"}' == '6' AND '{current_time format="%G"}' == '17') OR ('{current_time format="%w"}' == '0' AND '{current_time format="%G"}' >= '9' AND '{current_time format="%G"}' <= '11')}
    {exp:weblog:entries weblog="live" limit="1" show_future_entries="yes" show_expired="yes" dynamic="off"}
    {live_body}
    {/exp:weblog:entries}
    So that statement does something like: If it’s Saturday, in the hour of 5 pm, then show the graphic. OR if it’s Sunday, from the hours of 9 to 11, then show the graphic.
    I think it should work perfectly.
  • #5 / Feb 13, 2009 11:18am
    Kris Khaira
    No problem. I hope your code worked. What problem were you having with Repeet?
