custom error page on simple search
January 22, 2009 2:11pm
Subscribe [6]
  • #1 / Jan 22, 2009 2:11pm
    exmonkey
    is there any way of using a proper template for search errors (ie searches of less than 3 chars) in the same way as we use one for no results (ie no_result_page=“noresults”)?
    I don’t like having to use the special user message template, because I cannot use embeds or in fact any EE variables (unless I’m missing something)
    Cheers
  • #2 / Feb 01, 2009 8:08pm
    Alejandro Mut
    Same issue here! Is there any solution to exmonkey’s question?
  • #3 / Feb 05, 2009 6:39pm
    stdrovia
    I would like to know if there is a solution to this too. I need to replace the error pages for submitting a blank search and for searching more than once in 15 seconds. Also, can the search time limit be changed?
  • #4 / Mar 05, 2009 5:20am
    Also looking for exactly the same error page customization?
  • #5 / Mar 25, 2009 6:22pm
    xotox
    am also looknig for a solution
  • #6 / Apr 16, 2009 1:04am
    Andrew Hedges
    @stdrovia - You can set the minimum time between searches by going to Admin > Members and Groups > Member Groups. I guess it’s tucked away there because it’s a setting per user group. I would never have looked there, myself.
    I, too, would like to use a custom template when no results are found for a keyword search. Anyone?
  • #7 / Apr 16, 2009 1:07am
    You mean something like no_result_page=?
  • #8 / Apr 16, 2009 1:12am
    Andrew Hedges
    Ha ha. You beat me to it. I just found this parameter by digging around a little more. However, I’m still getting the default message, just with a different URL. Any ideas?
  • #9 / Apr 16, 2009 1:13am
    Andrew, if this isn’t working I’m going to ask you to post some details over in Tech Support.  Version, extensions, and your code would be a great start to get you some help =)
  • #10 / Apr 16, 2009 1:15am
    Andrew Hedges
    Thanks, Lisa, I found the following thread that I think will solve my problem: http://ellislab.com/forums/viewthread/27728/
    The trick is not to include the search results tag in the no results template. Makes sense in a way, but means you can’t use the same template for both cases. C’est la vie.
  • #11 / Apr 16, 2009 1:22am
    Can’t say I’ve ever been much of a fan of multi-use templates; I prefer having multiple, lean templates.  Easier to code and work with, and with embeds, not harder to maintain.
    In any case…. I ramble.  If that doesn’t resolve it, please post in tech support. =)
  • #12 / Apr 16, 2009 1:30am
    Andrew Hedges
    I’m not a “fan” of multi-use templates, either. I am a fan of showing my users /path/search/ for all search results pages, whether or not there are any matches. I’d love to know if that is possible. From what I’ve seen it is not.
  • #13 / Apr 16, 2009 1:32am
    Put it all in a search template group? =)
