This will probably be viewed as a dumb question; but, please no dumb answers 😊
Where can you delete comments from the control panel or for that matter manage them?
January 18, 2009 10:26am
Subscribe [2]#1 / Jan 18, 2009 10:26am
#2 / Jan 18, 2009 10:48am
Hi Herb,
If you have any comments when you log into your control panel and go to the Edit page then you should see a column that is called comments. This will show how many comments there are for each entry and you can enter into the comments for the entry from here and then edit / delete / moderate them from here.
I think that if you have no comments at all in the system then this column doesn’t show. I could be wrong on that though as it’s been a while since I installed my system and have quite a few comments in there.
Best wishes,
Mark
#3 / Jan 18, 2009 10:57am
Thanks Mark:
Once again you are spot on with the right answer.
Herb
#4 / Jan 18, 2009 11:16am
No problem.
Hope everything goes well for you.
Best wishes,
Mark
