In a nutshell, I am toying with the idea of having java pop-up comment form instead of moving to a new page request.
The problem I see with java is that you don’t know if the visitor has java enabled or not; resulting in the need to have the java pop-up (if java is enabled) or a link for a new page request (if java is not enabled).
I’ve thought about having the pop-up link in a hidden div and the link for new page in a visible div and switching their visible property with java; however, this would would require placing the pop-up form in the html irregardless of java enabled state.
So…. the $64 questions are:
Does anyone have a cleaner way to handle this?
-or-
Should I just skip the cute java thing and stay traditional with just moving to a new page for comment entry?
