Usage of Conditionals - executed queries
January 08, 2009 12:19am
  • #1 / Jan 08, 2009 12:19am
    Erdal Demirtas
    I have a template like this:
    (I enabled “Display SQL Queries” and “Display Template Debugging?” options to see what’s happening.)
    {if segment_4}
    TESTING SEGMENT 4
    {if segment_4 == "" && segment_3 != ""}
    TESTING SEGMENT 3
    {exp:weblog:entries weblog="myweblog" url_title="{segment_3}" status="open" disable="member_data|trackbacks|categories|category_fields|pagination" dynamic="off"}
    <div id="article">
    <h1>{title}</h1>
    {body}
    </div>
    {/exp:weblog:entries}
    If I have an url like this -> http://www.domain.com/seg1/seg2/seg3/seg4/
    I expect to see just “TESTING SEGMENT 4” and “exp:weblog:entries” tag in the second condition should not be executed.
    RESULT: I see only “TESTING SEGMENT 4” as expected but the tag in the second condition is being executed.
    What am I doing wrong?
    Are the conditionals only for displaying tag outputs?
    Or is it the parse order?
    What should I do so that only the contents of “TRUE” condition will be executed?
    p.s.
    Version: 1.6.6 - Build: 20081212
  • #2 / Jan 08, 2009 11:30am
    Tim Stackhouse
    Try this:
    {if segment_4}
    TESTING SEGMENT 4
    {if:elseif segment_3}
    TESTING SEGMENT 3
    <div id="article">
    <h1>{title}</h1>
    {body}
    </div>
  • #3 / Jan 08, 2009 11:45am
    Erdal Demirtas
    Thank you, but it does not help, I’ve already tested it.
    Template Debugging says:
    ...Parsing Tags in Template
    and all the tags in a template will be processed.
    The conditionals have no effect.
    If this is really the behaviour, I can even stop using EE.
    I do not want to use tons of embeds which is not good for performance.
    I hope there is an answer to this.
    I habe been waiting since last night.
    Thank you again.
  • #4 / Jan 08, 2009 11:51am
    Erdal, what is the reasoning behind what you’re trying to do? It might be easier to figure out a solution if we knew what the end result is.
  • #5 / Jan 08, 2009 12:14pm
    Erdal Demirtas
    Hi Sue,
    what i am trying to do is not really complex. It is described above.
    I have some logic in my template depending on the segments:
    If there are 4 segments do this
    If there are 3 segments do that
    If there are 2 segments do ...
    and so on
    The first segment is the name of the weblog and template-group.
    The others are entries in that weblog.
    What I want to learn is the behaviour of the EE in this case:
    “All” the tags will be processed in a template whether they are in a “TRUE” condition or not.
    Is this correct?
    This is what i understand from the results of debugging.
    You can easily test this. The template is really not complicated.
    As an experienced programmer I need this for lots of use cases, not only for this one.
    I expect that only the tags in the condition which TRUE to be executed.
    Let’s say there are 4 conditions in a template which only one of them can be TRUE at a time.
    But if at each request all the tags of all conditions will be processed, you end up with lots of unnecessary queries.
    If this is the case I must think about the whole software architecture.
    I really want to understand the behaviour of EE in this case.
  • #6 / Jan 08, 2009 12:24pm
    The way that EE works normally is for the third segment to hold the url_title of an entry. The fourth segment isn’t usually used for additional entries.
    As an example, let’s use a t-shirt.
    http://example.com/index.php/tshirt/order/sunset-tshirt/xxl/long-sleeve
    tshirt is the first segment, the template group name
    order is the template, second segment.
    sunset-tshirt is the weblog entry.
    xxl is a modifier for the sunset-tshirt for the size, (segment_4)
    long-sleeve is another modifier for sunset-tshirt in segment_5.
    But what you’re asking for I’ll go find out.
  • #7 / Jan 08, 2009 12:32pm
    Erdal Demirtas
    Hi Sue,
    thank you for the answer.
    I know how EE normally works.
    Because of this I have “dynamic=“off” in my “exp:weblog:entries” tags.
    What I am asking is totally different.
  • #8 / Jan 08, 2009 12:38pm
    Give this a try:
    {if segment_4 == ""}
    {if segment_3 != ""}
    TESTING SEGMENT 3
    {exp:weblog:entries weblog="default_site" limit="7" dynamic="off"}
    <h3>{title}</h3>
    <p>{summary}<br />
    <hr><br />
    {body}<br />
    {/exp:weblog:entries}<br />
    {/if} <br />
  • #9 / Jan 08, 2009 1:18pm
    Erdal Demirtas
    Thanks it works!
    I think this sentence of the documentation is the explanation:
    NOTE: Advanced Conditionals are evaluated after all EE tags are parsed.
    TEST 3
    is not equal to
    TEST 3
    The second one has advance conditionals.
    I hope there are not lots of people using this falsely as I did.
    As I said before the output is always correct but lots of queries are being processed at the background.
    Thank you again.
  • #10 / Jan 08, 2009 1:43pm
    Pascal Kriete
    Oh those evil parse order things 😉 . Looks like Sue got you squared away though.
    Please don’t hesitate to post again as needed.
