1.6.6: Publish and Edit screens blank for one specific weblog
January 03, 2009 5:59am
  • #1 / Jan 03, 2009 5:59am
    Jan_Huygens
    I’ve recently updated my sites to EE 1.6.6 build 20081114.  Several of these sites have a weblog for events, which uses the dates and has fields for descriptions etc, inc a geocode field [Mark Huot’s extension] for a google map - but otherwise the weblog only has about seven fields [text].
    These sites use same host, but on one site, the publish and edit pages appear completely blank when I try to access them for this weblog. :-(
    Existing entries in this weblog display ok in the actual website, so they have not been deleted.
    The other weblogs display fine in the CP, including one which also has a geocode field.
    I have enabled the ‘display PHP/MySql error messages for superadmins’ in Admin/System Prefs/Output and debugging prefs - and set
    error_reporting(E_ALL);
    in System/Index.php.  But I still get NO error messages when I try to publish or edit.
    Any ideas?
  • #2 / Jan 03, 2009 3:11pm
    Jan, can you go to Admin -> Utilities -> PHP Info and look for display_errors and let us know what it says? While you’re there, let us know what memory_limit says as well, please.
  • #3 / Jan 03, 2009 5:08pm
    Jan_Huygens
    Hi Lisa
    hmmmmm
      display_errors are ‘off’
    [which seems to contradict the output prefs setting]
    The memory limit is 128MB [PHP Version 5.2.6]
    Does that give a clue?
  • #4 / Jan 03, 2009 6:49pm
    That means that your PHP environment is suppressing errors; that’s something that your host will need to toggle for you so that ExpressionEngine can display errors.
  • #5 / Jan 03, 2009 6:59pm
    Jan_Huygens
    ok - i’ll get onto them. Probably be on Monday.
  • #6 / Jan 04, 2009 3:36pm
    Greg Aker
    Jan_Huygens:
    Please keep us posted on if your host will turn on errors.
    -greg
  • #7 / Jan 05, 2009 4:04am
    Jan_Huygens
    will do - am just waiting for a reply to an email to the host sent last night.
  • #8 / Jan 05, 2009 7:42am
    Jan_Huygens
    OK - error reporting on
    I get the following ‘cleaned’ error messages:
    Warning: Publish::include_once() [publish.include-once]: Unable to access /usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/lib/js_calendar.php in /usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/cp/cp.publish.php on line 1797
    Warning: Publish::include_once(/usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/lib/js_calendar.php) [publish.include-once]: failed to open stream: No such file or directory in /usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/cp/cp.publish.php on line 1797
    Warning: Publish::include_once() [function.include]: Failed opening ‘/usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/lib/js_calendar.php’ for inclusion (include_path=’.:/usr/local/psa/apache/lib/php:/usr/local/share/pear’) in /usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/cp/cp.publish.php on line 1797
    Notice: Undefined variable: CAL in /usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/cp/cp.publish.php on line 1809
    Fatal error: Call to a member function calendar() on a non-object in /usr/local/psa/home/vhosts/mysite.com/httpdocs/system_folder/cp/cp.publish.php on line 1809
  • #9 / Jan 05, 2009 10:34am
    Pascal Kriete
    Jan, it looks like you’re completely missing a file.
    Can you please update your files to the latest build.  That will hopefully sort out the missing files.
    Let us know how it goes.  Thanks!
  • #10 / Jan 05, 2009 12:58pm
    Jan_Huygens
    OK will do that now
    Funny though, one would have thought that the other weblogs would show a similar problem… don’t they all use the calender?
  • #11 / Jan 05, 2009 1:31pm
    Jan_Huygens
    That did the trick 😊
    thanks all!
  • #12 / Jan 05, 2009 1:32pm
    Greg Aker
    Jan_Huygens:
    I’m glad that did it for you.  Please don’t hesitate to start a new thread should anything else come up!
    -greg
