Overlapping problems
January 02, 2009 1:21pm
  • #1 / Jan 02, 2009 1:21pm
    smeg
    Based off an EE template, I’m trying to add a drop down menu to one of my Nav buttons.
    Unfortunately, when you are at a page that contains a flash gallery, the drop down menu *sometimes* goes *behind* the flash window.
    It doesn’t seem to be browser specific, I get it in FF2 and IE6 at work, but not FF3 and Safari at home. I can’t do much more testing than that, unfortunately, due to restrictions in what browsers I run in the office. I get mixed reports from my users.
    The pages affected are:
    http://www.rt2photo.com
    The drop down menu is on the “Portfolio” button, and any of the Portfolio pages run a flash gallery.
    Thoughts?
  • #2 / Jan 03, 2009 3:27am
    MeanStudios
    Where you are using swfobject to post your flash (like on: http://rt2photo.com/portfolio/individualandchild/)
    try replacing the javascript code with this:
    [removed]
            var fo = new SWFObject("viewer.swf", "viewer", "100%", "100%", "7", "#181818");
            fo.addVariable("preloaderColor", "0xffffff");
            fo.addVariable("xmlDataPath", "gallery.xml");
            fo.addVariable("wmode", "transparent");
            fo.write("flashcontent");
        [removed]
    Not sure if it will work, but we’ll see 😉.
  • #3 / Jan 03, 2009 9:29am
    smeg
    Codysplace:
    I’ve made the change to the individual and child portfolio page, and will check out of the menu overlaps when I hit the office on Monday, of course I can’t make it overlap badly.
    one oddness though - with the new code, the slideshow doesn’t autoplay - it stalls on the download flash page.
    Thoughts?
    Thank you for looking at this!
  • #4 / Jan 03, 2009 4:44pm
    MeanStudios
    I messed up, it should be:
            fo.addParam("wmode", "transparent");
    Put that in between your “< script >” tags.  The line you need to add to all your swfobj code is this:
    .  That should make it so things can go over top of the flash.
  • #5 / Jan 04, 2009 12:26am
    Marcus Neto
    Why not just use CSS?
  • #6 / Jan 04, 2009 12:29am
    MeanStudios
    I do not think you can use CSS to make flash not cover other elements without using the param I posted above.
  • #7 / Jan 04, 2009 12:37am
    Marcus Neto
    Sorry, it is late and I responded without looking really hard at what the problem was. I went to the site and saw an overlapping problem with the menu where it was overlapping a navigation element and posted based on that. You are correct that the transparent code that you posted should fix the issue. Sorry…
    M.
  • #8 / Jan 04, 2009 12:46am
    MeanStudios
    No worries, I see what you mean though, it would be better to use CSS for the menu system then use all of that javascript.
  • #9 / Jan 07, 2009 12:15pm
    smeg
    I’m not particularly experienced when it comes to building sites from the code up - if CSS was a better way to do this, and someone could assist with some resources or links, I’d have no problem switching over.
    I’m going to try the updated code today - thanks for the assist!
  • #10 / Jan 08, 2009 7:27pm
    smeg
    I just wanted to publicly thanks CodysPlace.com for the excellent information - it resolved my problem!
    Thanks Cody!
  • #11 / Jan 08, 2009 7:53pm
    MeanStudios
    No worries mate!  I had the same thing happen to me a year ago or so and I know how frustrating it can be when it’s such an easy fix like that 😊.
    To answer your question above, I’ve been looking and I’m not sure there are CSS tabs that show that drop down menu without using a bit of javascript.  The following link might provide you a better solution than what you are using now: http://www.dynamicdrive.com/dynamicindex1/droptabmenu.htm
    Seems to be a bit cleaner.
    Best Wishes!
