Hello everyone.
I’ve done some searches here as well as in the Knowledge Base, however I can’t find an answer. My apologies if I missed it and am wasting someone’s time.
I would like to limit an Archive list to a specified amount and add pagination links.
So basically, by visiting a page, instead of having a very long list of every single post, you’d limit to a specified amount and there’d be the pagination links at the bottom to get to all of the posts.
It’s because I’m using a static web page design and if all the items are listed, it’ll break the site.
I removed the disable pagination in the archives tag, but no page links appear… and when I add the pagination link, it doesn’t display properly in the site (shows the code).
Any help would be appreciated. Thank you kindly.
