“Your system folder path does not appear to be set correctly” - urgent
March 02, 2011 1:20am
  • #1 / Mar 02, 2011 1:20am
    chilli_group
    Hi All,
    I’ve ready through several of these topics but none seem to be able to fix my problem.
    I’ve just moved a website from a devleopment folder to the root directory to make it live.
    moved from ‘/dev/’ to just ‘/’ which is the root directory.
    I left the root directory index.php as is
    $system_path = './cms';
    and I changed the config.php from
    $config['cp_url'] = "http://www.mysite.com.au/dev/cms/index.php";
    to
    $config['cp_url'] = "http://www.mysite.com.au/cms/index.php";
    and the baseurl
    $config['base_url'] = "http://www.mysite.com.au/";
    instead of /dev/ on the end.
    But I’m still getting the Error
    “Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php”
    Any ideas?
    Running EE 2.1.3
  • #2 / Mar 02, 2011 2:10am
    Enviromed
  • #3 / Mar 02, 2011 3:04am
    chilli_group
    still having problems…
    I’ve implements the DRY principle files and configured them all as per instructions here: http://net.tutsplus.com/tutorials/php/apply-the-dry-principle-to-build-websites-with-expressionengine-2/
    Still getting the same error:
    I’ve even done a search of all my code on the entire site to see if I could find something with ‘/dev’ but couldn’t find anything.
    Is there something I can try with the index.php file?
  • #4 / Mar 02, 2011 2:23pm
    Hi, chilli_group.
    What is in your config.php file? What’s in the index.php file? In other words, what did you change?
  • #5 / Mar 02, 2011 7:08pm
    chilli_group
    Ok, I worked it out. (Feel pretty silly)
    When Transmit (FTP Progam) moved everything on the server, it missed moving the ‘codeigniter’ folder inside my system folder.
    So I re-uploaded it, and it all seemed to be working ok…
    Didn’t even think of checking that kind of stuff…
    Thanks for your help guys!!
  • #6 / Mar 02, 2011 10:02pm
    We’ve all had that happen to us one time or another.. Glad things are working again. Don’t hesitate to post again as needed.
