First of all, I’d like to thank EL for making such a great software!
I have a few very broad questions and some narrow ones. I will try to list them here, hoping for an answer.
1. How does EE parse the URL’s ? They seem to just magically get parsed, /2008/08 gives the monthly archive, /comments/post-name gives the current post, etc. I can find nothing inside the index template nor the comments template that handles the URL’s, other than {exp:weblog:entries}. The reason I am asking is that I want to be able to have better control over this. I want to create permalinks looking like /2008/08/09/post-title, I want to be able to avoid using the template-group’s name in the URL, I want to be able to use the category name inside the URL, and more. Is there somewhere I can manually edit the URL’s to fit me? Not using htaccess, that is.
2. What does the Path-setting of Weblog Administration actually change? Can it be the answer to question 1 ?
3. How does the Pages module work (I have not bought this, however I am looking at a friends purchased version) ? Does the /example/page/uri come directly from index.php ? (Would making a page with that url end up with http://test.com/index.php/example/page/uri ?)
4. What is the difference between URI and URL (sorry if I have mixed these up in my post) ?
5. I know that you do not want to set a release date for v2.0, but is there any indication, whatsoever, to when it is getting released?
Thank you all in advance,
Douglas.
