I would like to list some meta data with each post from a specific weblog like so:
* Post 1 of 4
* Post 2 of 4
* Post x of y, etc…
So I want to know the position of each post within its corresponding weblog.
Thanks for any help!!
July 19, 2008 7:47pm
Subscribe [3]#1 / Jul 19, 2008 7:47pm
* Post 1 of 4
* Post 2 of 4
* Post x of y, etc…
#2 / Jul 19, 2008 8:10pm
If you are listing the entries in chronological order (by date), wouldn’t they be that way already so it would just be adding…
Post {count} of {total_results}
#3 / Jul 19, 2008 8:15pm
Yes, but {count} is only returning the order number from the query, not the order that it was posted
#4 / Jul 19, 2008 9:24pm
As mentioned though, if you are using the sort variable in the weblog:entries tag for chronological they’d be in the order by when they were posted, 1st, 2nd, etc., so the count should reflect that. Is there something I’m not understanding/getting.
#5 / Jul 20, 2008 1:22am
Gotcha, that is what I thought too. But no matter what sort order I put on the entries tag, the number that {count} renders is the same.
You can see what I am trying to accomplish here: http://thenew.c3greensboro.com
Look in the two entries under the First Experiences area on the home page. I am trying to work out the Experience No. X at the bottom of each entry.
Thanks so much for your attention to this!!
#6 / Jul 20, 2008 3:48am
I see Experience $1 and #2 - Is not that correct?
#7 / Jul 20, 2008 4:52am
No. John and Britten Peele were entered into the database first, so they should be #1. And then when I enter a third entry, John and Britten will fall off, Paul and Elizabeth Geisen should move to the right, and the new entry should display in the first spot as #3. (None of that is animation, just me describing what will take place when I have more than 2 entries in the DB)
#8 / Jul 20, 2008 5:19am
Ok, then there will be a problem as the {count} variable is based on what’s displayed and you’re displaying in descending order. So {count} won’t work, If you always have just the latest two, the count will always be #1 & #2 in the wrong sequence.
There isn’t a standard tag way to do it that I know of. I believe you’d need to query the database for all entries by date/ascending and determine the number from that array for those two displayed entries. I don’t have any query mojo so don’t know how exactly you’d do it. The query wouldn’t be too bad with a few entries but once you get a lot it could be problematic because you have to get them all I believe.
If you want to go that route, hopefully someone with some php or query skills will pop in.
#9 / Jul 20, 2008 5:26am
Another way I suppose would be to use a standard weblog:entries tag to get all entries and just not display it. Set it (css) to display hidden or none. Use the {total-results} from that as a variable for some php math. The two displayed entries will always be the total_results and total-1 if there are always just two displayed. A query is probably better though.
#10 / Jul 20, 2008 5:33am
If you never delete an entry, it would be as simple as using the entry_id. Otherwise, you’d have to count all entry_ids smaller or equal to the current one. Makes sense?
SELECT COUNT(entry_id) FROM exp_weblog_titles WHERE entry_id <= '{entry_id}' AND status <> 'closed'You’ll probably want to use the query module, and need to repeat that for every entry in your weblog:entries loop.
#11 / Jul 20, 2008 5:45am
Ingmar - Would that apply if you have multiple weblogs and you only need this for one of them?
#12 / Jul 20, 2008 5:57am
Yes. Depending on your preferences, you could restrict the count to one weblog only, or count them all, but only have a subset of them displayed, like “entry #99”, “entry #103” and so on (entries 100 - 102 would be in a different weblog, not shown on this template).
Basically, all you’d need to do is add another WHERE clause:
... WHERE entry_id <= '99' AND status <> 'closed' AND weblog_id = '3'#13 / Jul 20, 2008 4:48pm
Thanks for all the help guys, but let me be sure that I am explaining my issue correctly. Here is my code block:
{exp:weblog:entries weblog="firstexperiences" disable="member_data|pagination|categories|trackbacks" dynamic="off" limit="2"}
<div class="experience trans-black-40 span-6{switch="| last"}">
<a href="#" title="">{video}</a>
<h4>{title}</h4>
<p> <a href="#" title="Watch it now">Watch it now ></a><br />
{entry_date format="%m.%d.%y"}<br />
Experience No. {entry_id}<br />
</div> <!-- experience ends --><br />
{/exp:weblog:entries}Right now, I am using {entry_id}, but obviously that is not going to render the results I am wanting. The two entries that I have currently displaying on my dev site should be displaying as Experience No. 2 & Experience No. 1 (in desc order). So when I add the next post in the firstexperiences weblog, the numbers should shift to Experience No. 3 & Experience No. 2 (again in desc respective order).
No variation of {count} or query has worked so far, nor do I think it will. I need to know, of the total number of entries in the firstexperiences weblog, the ordinal position of each post. If the solution is always respective to the QUERY I am looping through, then I will ALWAYS get results such as 1 of 2 & 2 of 2. But I needs positions relative to the order in the database, not the query result set.
I hope that helps.
Thank you again!
#14 / Jul 20, 2008 5:45pm
Well, this is working fine for me, unless I completely misunderstood what you are looking for:
{exp:weblog:entries weblog="default_site" status="not closed"}
{exp:query sql="
SELECT COUNT(entry_id) AS ordinal FROM `exp_weblog_titles`
WHERE entry_id <= '{entry_id}' AND status <> 'closed' AND weblog_id='1'"}
entry #{ordinal} - entry_id: {entry_id} - {title}
{/exp:query}
{/exp:weblog:entries}#15 / Jul 20, 2008 6:26pm
Ingmar…. you are a life-saver!!!
Thank you, thank you!!
