entry pagination question - if last post conditional
June 08, 2008 3:58am
  • #1 / Jun 08, 2008 3:58am
    Corey Lane
    I have entries from a weblog paginated, 5 per page. I have a divider image in my template that goes in between each blog entry. Link to page The problem is, the divider shows up on the last post of the page, creating an unnecessary divider. Is there anyway with an if conditional or some other method to NOT show the divider if the entry is the last entry on the page.
    {exp:weblog:entries weblog="staff" sort="asc" limit="5" paginate="bottom"}
      <div class="staff-member">
        <h3 class="clear"><a href="http://{path=about/staff/{url_title}}">{title}</a> - {position}</h3>
        {staff-photo} {staff-member-bio}
            <!-- blog entry divider -->
            <div class="hr"><hr ></div>
      <!-- close staff-member -->
      </div>
      {paginate} {pagination_links}{/paginate}
     {/exp:weblog:entries}
  • #2 / Jun 08, 2008 10:48am
    Try it with
    {if total_results Q= count}
    Think that should do the trick.
  • #3 / Jun 08, 2008 3:00pm
    Corey Lane
    Robin, I tried your code and received the following error on the page:
    Parse error: syntax error, unexpected T_STRING in /home/wbcweb/public_html/system/core/core.functions.php(637) : eval()'d code on line 26
    EE 1.6.3 / Build: 20080421
  • #4 / Jun 08, 2008 5:43pm
    Mark Bowen
    I think maybe Robin slipped on the keyboard earlier maybe? 😉
    The code should be :
    {if total_results == count}
    Hopefully that should do it for you.
    Best wishes,
    Mark
  • #5 / Jun 08, 2008 6:01pm
    Corey Lane
    Hi Mark, thanks for your response. Close, but no cigar…
    That code puts the divider on the last post only. I want the divider on every post but the last. I threw in an if:else which solved that issue. Thanks to both of you for the help!
    The first if statement is empty, is that kosher? It seems to be working exactly the way I want it to.
      {if:else}
      <!-- blog entry divider --><div class="hr"><hr ></div>
  • #6 / Jun 08, 2008 6:24pm
    Mark Bowen
    Oops sorry!
    Didn’t read the post correctly.
    Should be this code then :
    {if total_results != count}
    Best wishes,
    Mark
  • #7 / Jun 09, 2008 12:58am
    Corey Lane
    Thanks again Mark.
  • #8 / Jun 09, 2008 1:26am
    Corey Lane
    I always forget about global variables, they are helpful.
    {divider}
  • #9 / Jun 09, 2008 5:56am
    Mark Bowen
    Yep you can do that too 😉
    Glad you are all set now.
    Best wishes,
    Mark
  • #10 / Jun 09, 2008 10:29am
    Heh- for some reason I had a Q instead of an equal sign in the example code.  😉  Yea- that wouldn’t work.
    Glad Mark got you squared- I’m closing this on out.
