Passing variables to embedded templates
April 27, 2008 10:27pm
  • #1 / Apr 27, 2008 10:27pm
    seajay
    This is related to http://ellislab.com/forums/viewthread/4076/
    I am working to modularize my project by moving common template elements to embedded templates.
    However, I’m having trouble understanding how to pass variables to the embedded templates.
    For example, I wish to pass {entry_date}. I’ve tried
    {embed="content-blocks/date" pass_entry_date="{entry_date}"}
    Then in content-blocks/date, I have:
    {{embed:pass_entry_date} format='%l %M %d  %Y'}
    However, I am getting:
    {1209280680 format=' %l %M %d %Y'}
    What am I doing wrong? Are there any threads that go into more detail about passing variables?
  • #2 / Apr 28, 2008 3:28am
    Try this:
    {embed:pass_entry_date format="%l %M %d  %Y"}
  • #3 / Apr 28, 2008 9:58am
    seajay
    Hmmm.
    The containing template:
    {exp:weblog:entries weblog="{embed:current_weblog}" limit="1"}
    {embed="content-blocks/date" current_weblog="{current_weblog}" current_template_group="{current_template_group}" pass_entry_date="{entry_date}"}
    {/exp:weblog:entries}
    Now, I put this in the embedded template”
    This is what I’m seeing.
    1209280680 {embed:pass_entry_date format="%l %M %d %Y"}
    The date appears to be passing (I assume that “1209280680” is the numeric date value).
    However, for some reason the format date processing isn’t happening. Do I have to turn it on somewhere?
  • #4 / Apr 28, 2008 10:19am
    seajay
    Correction. I discovered one problem: in multiple nested templates, one must add embed to to beginning of variables.
    So, they’re all working except ... the passed entry_date variable appears as 1209280680 but, as soon as I add formatting code, the variable breaks.
    So ...
    ... appears as ...
    1209280680
    However ...
    {embed:pass_entry_date format="%F %d %Y"}
    ... appears as ...
    Here’s my original note; now irrelevant.
    Additional info: none of my embed statements are being parsed.
    {current_weblog} {current_template_group} 1209280680
    I added a {exp:weblog:entries} loop around the fields and they just disappeared.
    I think I’m missing something very basic about assign variables, or configuration.
    Any ideas? Links to threads that clarify passing variables to embedded templates?
  • #5 / Apr 30, 2008 5:18pm
    What if you format the date in the calling template, so to speak:
    {embed="content-blocks/date" pass_entry_date="{entry_date format='%l %M %d  %Y'}"}
    And then simply {embed:entry_date} in the embed? If that fails, you can certainly use PHP to achieve what you’re after, but it seems like overkill.
  • #6 / Apr 30, 2008 5:42pm
    seajay
    Bingo. Thank you!
  • #7 / Apr 30, 2008 5:43pm
    Woot 😊 Closing for now.
