SOLVED: Site Map and LG Poll module don’t place nice together
the_crimsonrooster's avatar
the_crimsonrooster
18 years ago
the_crimsonrooster's avatar the_crimsonrooster
I just encountered an interesting error in regards to the LG Polls and Sitemap modules. I was creating my first poll and selected update. I get the following error:
“Notice: A session had already been started - ignoring session_start() in /extensions/ext.sitemap_pinger.php on line 153.”
I noticed I had the “Send sitemap ping to search engines” checked. So i went to the site map module control page and excluded the lg polls. However, when I go back to the LG Polls weblog, its still selected.
By the way the poll does get created.
I try to create another poll. This time making sure the send to site map ping is not selected. Same error.
has any one else run into these problems. Any ideas.
I’ll email this to LG also.
Lisa Wess's avatar
18 years ago
Lisa Wess's avatar Lisa Wess
Since this is about two third-party extensions, I’ve moved it down to the Modules forum. I would recommend definitely contacting the authors directly as well.
Ben @PutYourLightsOn's avatar
18 years ago
Ben @PutYourLightsOn's avatar Ben @PutYourLightsOn
thanks for the notice, i’ll look into this and get in touch with leevi to see if we can track the cause
the_crimsonrooster
18 years ago
Now I also get the error anytime i update a regular entry. After, i uninstalled and reinstalled the Site Map module - things seem to work fine.
the_crimsonrooster
18 years ago
I was wrong. After I reinstalled the Site map module, and resubmitted an entry. I get the following error:
Notice: A session had already been started - ignoring session_start() in /extensions/ext.sitemap_pinger.php on line 39
Warning: Cannot modify header information - headers already sent by (output started at /extensions/ext.sitemap_pinger.php:39) in /core/core.functions.php on line 296
Leevi Graham's avatar
Leevi Graham
18 years ago
Hey guys,
One of the issues is that Site Map Pinger is not checking if a $_SESSION has already started. This can be resolved by adding:
if (session_id() == "") session_start(); // if no active session we start a new one
Cheers Leevi
18 years ago
you can add the above line of code to line 39 of ext_sitemap_pinger.php to solve the issue. i will add it to the current version.
Leevi Graham
18 years ago
Thanks Ben
18 years ago
thanks leevi, and well done on an excellent polls module!
Leevi Graham
18 years ago
Hey therooster,
Any chance of getting this thread title updated to: “SOLVED: Site Map and LG Poll module don’t place nice together” ?
Cheers
the_crimsonrooster
18 years ago
I’ll test today and let you know the results.
the_crimsonrooster
18 years ago
I get this error when testing:
“A session had already been started - ignoring session_start() in extensions/ext.sitemap_pinger.php on line 153”
This is what my updated ext.sitemap_pinger.php line 39 looks like
// start session
            $_SESSION['sitemap_pinger'] = array();
18 years ago
oops i forgot to mention that the condition also needs to be added on line 153
the_crimsonrooster
18 years ago
I downloaded the newest update from your site and everything appears to be working. Let me work with both a little more and if all goes well, I’ll update the title. Also, the previous problem seemed to be killing the “Restricted Entries” ext, but now all seems to be working fine.
