I’ve got an odd problem (cue stupid, but still funny jokes about seeing a doctor etc)...
For reasons I won’t go into I need to run two forum boards through templates. So, in each board prefs I’ve removed the trigger word and defined the URL for each as segment_1 words respectively. Each template index (in groups named the same as the segment_1 words above) then just contains {exp:forum}. When I add one board in this way then the forum is rendered correctly although oddly it seems as if it’s not running through the full template parser since EE comments are rendered to the browser. If I add another board then neither board works correctly the {lang:whatever} constructs are not parsed, just output to the screen.
It’s entirely possible that this is in fact not supposed to work and I’m imagining that I’ve done this before.
If you have actually managed to do this please let me know how you did it 😊
In the meantime I’m gonna top up on tea and nicotine and hope that my brain kicks into gear sometime in the next 100 years or so…
Cheers
Dry
P.S. Both EE and Forum are latest versions/builds
