No URL Found Probelms with ExactURL-Plus
Eastwood Design's avatar
Eastwood Design
18 years ago
Eastwood Design's avatar Eastwood Design
I have exacturl-plus plugin installed and when I try and use this code
{exp:extract_url_plus show="% fullfilename"}{main-image}{/exp:extract_url_plus}
I get this when viewed in the browser
No URL Found
{I added the space after % just here in the forum)
Sue Crocker's avatar
18 years ago
Is {main_image}’s format set to none?
Eastwood Design
18 years ago
main-image was added with the file upload extension so there is no choice for formatting
I also tried another textfield using the EE upload utility and tried setting the field to none, auto, and xhtml and all are returning the error No URL Found
text field usong ee upload, still not working
{exp:weblog:entries weblog="listing"}
{exp:extract_url_plus show="% filename.% extension (% filesize)"}
{image-1}
{/exp:weblog:entries}
added spaces after % and &
Derek Jones's avatar
Derek Jones
18 years ago
Moving this to the Plugin forum, as we do not provide direct support for third party add-ons, and the plugin author will be more likely to see it (though a direct PM or email to the author may be the way to go).
Ty Martin's avatar
Ty Martin
18 years ago
Ty Martin's avatar Ty Martin
I’m getting the same problem when using this for our profile photos. They were working fine on the old server, now they’re not. Could it be a PHP5 issue (the old one was PHP4 I believe)?
I know the plugin is getting a good URL. Even when I type it in manually as a parameter it’s returning No URL Found.
Ryan M.'s avatar
Ryan M.
18 years ago
Ryan M.'s avatar Ryan M.
Same here. I’ve used this reliably in the past with Mark Huot’s File upload and phpThumb. This is the first PHP5 install I’m trying this combo on, and Extract URL seems to be returning No URL no matter what I do. Doh! Any PHP guru’s know how to tweak this so I can get it working?
(Running version 1.2.1 for the record)
Daniel Walton's avatar
Daniel Walton
18 years ago
Daniel Walton's avatar Daniel Walton
The plugin has been rewritten, please try the new version 😊
