SQL import (now via CSVGrab)
Matt Harris's avatar
Matt Harris
18 years ago
Matt Harris's avatar Matt Harris
Hi
we are currently re vamping a client’s site using EE and we have a large news section, i wanted to know if it is possible to somehow import all our news stories into EE?
[Mod Edit: Moved to the Plugins forum and expanded the title.]
18 years ago
It will depend a bit- if you can get them into MT format, EE has a built in MT Importer. That’s what I generally prefer. And as long as the old site is in a db, you can generally output to MT format easily enough. See the wiki on importing. Another option that some folks favor is the CSVGrab plugin- which basically let’s you import from a CSV.
So- just depends a bit on how the data are currently stored. If it’s a db driven site, there should be a workaround. (And if we get into details, I may shift this over to ‘How to’- depending).
Matt Harris
18 years ago
hi
i am trying to use CSV Grab plugin to import the SQL, im just getting a blank page. i put the following code in a blank template: {exp:csvee url=”http://www.thamesgateway.gov.uk/NewsItems.csv” weblog=”5” title=”1” skip=”1” delimiter=”;” encloser=”” use=”2|3” fields=”prod_description|prod_keywords” }
i view the template and i get a blank screen- is this correct?
im not too sure if im using the plugin correctly?
below are 2 entries from my csv file: 1;”Senior executive appointments announced at London Thames Gateway development corporation”;”The newly created London Thames Gateway Development Corporation ñ the organisation formed by the Government to deliver sustainable communities in the Lower Lea Valley and Barking/Havering Riverside has announced its first executive appointments.”;”1”;”0”;”6”;”2006-11-15 12:33:44”;”2006-03-22 09:09:09”;”2008-11-24 12:38:00”;”filesystem/Images/clg_logo_small.gif”
2;”£6 billion action plan transforming Thames Gateway to create thriving sustainable communities “;”A massive £6 billion programme to deliver high quality new homes schools health services jobs green spaces and transport links is transforming the Thames Gateway”;”1”;”0”;”64”;”2006-11-20 11:50:52”;”2005-03-31 11:50:52”;”2008-11-24 11:50:52”;”filesystem/Images/clg_logo_small.gif”
thanks
Sue Crocker's avatar
18 years ago
Is your data file still there? The link you posted isn’t found.
Matt Harris
18 years ago
Hi
thanks for the reply.
the file will not be accessible via public domain, i can pm it to you if you like?
thanks
18 years ago
Instead of PM’img me the file, can you zip it up and send to .(JavaScript must be enabled to view this email address)? Also please reference this thread.
Matt Harris
18 years ago
Hi
have you had a chance to look at this for me?
thanks
lukemcr's avatar
lukemcr
17 years ago
lukemcr's avatar lukemcr
I had the same “blank page” problem when using the CSVGrab plugin as well. What fixed it for me was removing a stray “|” from the end of the “use” parameter in the template I was using to upload the .csv file.
