Repeet- How to create a bookings calendar?
Peterbrady's avatar
Peterbrady
18 years ago
Peterbrady's avatar Peterbrady
I have set up a bookings calendar showing minicalendars for every month 2 years into the future.
I have set the calendars up to block off a particular date when I post to that date. This works fine. However, it’s time consuming when you have a month long booking and have to post to every date within that month.
I have played around with the Repeet plugin to get posts appearing between the start and finish of a booking. However, when I try to hardcode the month and year for each minicalendar (as I did without the Repeet plugin) it fails to show any dates as blocked out.
I would be grateful if anybody can suggest how I can hardcode the month and year into a Repeet minicalendar or offer an alternative solution to this.
For info this is the availability calendar as is : http://www.nuestrocastillo.com/mijas/availability/
Any help greatly appreciated.
18 years ago
Repeet was going to be my suggestion for multiple dates- but in truth, I haven’t used it myself. Still, I think it’s the best way to go- but as it’s a third party solution, this question will be a better fit down in the Plugins forum. For now, I’m going to shift it down there and tweak the title. You might also want to ask in the Repeet main post.
Peterbrady's avatar
Peterbrady
18 years ago
Thanks Robin.
I wasn’t getting much joy in the plugins forum and wondered if there might be an alternative to the repeet plugin?
