Separate mini calendars for each month using Repeet Plugin
Peterbrady's avatar
Peterbrady
18 years ago
Peterbrady's avatar Peterbrady
I am trying to set up mini calendars to display certain months by using for instance: month=”08” year=”08”
This does not seem to work with the Repeet plugin. Can anybody suggest how I might be able to get this working..
Thanks.
Jamie Poitra's avatar
Jamie Poitra
18 years ago
Jamie Poitra's avatar Jamie Poitra
Are you trying to do this all through the same template? I have gotten this to work with the default calendar tags by putting them into a separate template and embedding them in another template and passing start and end variables into them using embedded variables.
It may be that Repeet has something in it that is preventing a solution like that from working though. Mr. Wilson would need to answer that.
Jamie
