Weblog not working when viewing categories
August 31, 2007 7:27pm
  • #1 / Aug 31, 2007 7:27pm
    plebe
    Hi Folks,
    Having a weird problem where the weblog part of my footer (the footer is embedded) does not render when I view categories.  If I view a template directly such as: events/index the footer weblog shows up. If I click on a category link which points to self, it doesn’t work. Other embedded weblogs show up fine.
    I know the footer HTML comes in fine, just the weblog is not rendering.
    Where to start?
  • #2 / Aug 31, 2007 9:12pm
    Nearly impossible to say without knowing the code in your footer, but try out dynamic= by setting it to off.
  • #3 / Aug 31, 2007 11:23pm
    plebe
    Thanks Lisa,
    Yes, I have dynamic=“off” already. I’ll post the code later since I can’t right now.
    Initially I was just wondering if anyone has seen this issue. I searched, but found nothing relevant.
  • #4 / Sep 02, 2007 11:38pm
    plebe
    Hi Lisa,
    Here is the code for the footer. I’m also running the latest build. This was happening before the 8-15 build and still occurs. Now that I look at it, I’m using a {switch} inside a width parameter in a table. I thought the Switch tag in the width parameter of the table might be the issue, but I removed and still happens. Here’s the code:
  • #5 / Sep 02, 2007 11:45pm
    plebe
    ARGH!!  I had two “m’s” in dynamic.  ACK!  Sorry, that was it. It’s fixed. Man that is so lame.
    THanks, and I hope you didn’t do any detective work so far…
