EE1.6 upgrade - Hash values apppearing throughout site
June 25, 2007 4:27am
Subscribe [0]
  • #1 / Jun 25, 2007 4:27am
    Sam C
    I’ve just upgraded from EE 1.52 to EE 1.6, and I’m getting the value ‘M10o93H7pQ09L8X1t49cHY01Z5j4TT91fGfr’ appearing throughout my site in place of content.
    Two examples are:
    <title>{exp:weblog:info weblog="{my_weblog}"}{blog_title}{/exp:weblog:info}</title>
    This was working fine prior to the upgrade, and was not changed. It now outputs:
    <title>M00o93H7pQ09L8X1t49cHY01Z5j4TT91fGfr</title>
    Also, a few plugins seeming to be doing the same thing. One example (posted here) is doing the same sort of behaviour:
    {exp:static_page_root_path}
    <li class="{short_name} {current}"><a href="http://{url_title}" title="{title}">{title}</a></li>
    {/exp:static_page_root_path}
    now produces only:
    <ul>
    </ul>
    Furthermore, if I edit the plugin code and add the following:
    function Static_page_root_path ( $str = '' )
        echo "AAA";
        $this->return_data = 'AAA';
        exit();
    It has no affect - I still get the hash string result. It doesn’t look like the plugin code is even being executed.
    Any ideas?
  • #2 / Jun 25, 2007 10:46am
    From looking at it- do you have Mark’s ‘Pages’ module installed?  If so- there’s a conflict with EE’s new pages module- the Kblog has an entry on it.  That module needs upgrading prior to the upgrade to 1.6.0.
    But- before I dig into getting this up and humming again- do you have that module installed?  And if so, was it upgraded to the new ‘Tome’ prior to the 1.6 upgrade?
  • #3 / Jun 25, 2007 6:06pm
    Sam C
    I do, and I followed the Tome upgrade instructions prior to installing.
    Is there anything I can test/try?
  • #4 / Jun 25, 2007 7:46pm
    Paul Burdick
    Did you make sure to delete all of your caches after upgrading?
  • #5 / Jun 25, 2007 8:25pm
    Sam C
    Yup. Was careful to follow the Tome & EE upgrade instructions to the dot.
  • #6 / Jun 25, 2007 9:46pm
    Paul Burdick
    And these plugins still exist in the /system/plugins/ directory?  Those are placeholders for tag processing, so during the Template processing they are not being replace for whatever reason.  Typically, if a plugin/module is not installed, we throw an error, but that does not seem to be happening, and I see the cache as the most likely location of the problem.
  • #7 / Jun 25, 2007 11:10pm
    Sam C
    Ok—So can one plugin (such as Pages) affect other plugins? What confused me is that the {exp:weblog:info} tag was exhibiting this behaviour also.
  • #8 / Jun 26, 2007 12:21am
    Paul Burdick
    These strings of letters and numbers are inserted by the Template parser as place holders for tags during processing and are not directly relating to the tags or the module/plugin be called by them.  If you want me to take a look and figure out what the problem is, send me Control Panel login information, FTP login for your server, and the exact page where this is occurring.
  • #9 / Jun 27, 2007 2:26am
    Sam C
    Thanks for the offer Paul. This is a local testbed site though (no FTP server), with no real valuable data in it. I think I’ll just reconfigure from scratch on the new host (and possible switch to the EE pages module).
