mass edit solution...
ninja69's avatar
ninja69
19 years ago
ninja69's avatar ninja69
Hello,
I need a mass edit solution in order to set the status to ‘open’ or ‘close’ to several posts at once. Right now I have to set the status to every single post (after selecting the posts and pressing ‘Edit Selected’ )
Would somebody of you be able to code this for me? How much would it cost?
Laisvunas's avatar
Laisvunas
15 years ago
Laisvunas's avatar Laisvunas
Here is the version of the extension with smartpill’s fix.
