MSM site, how to share partials across sites?
From EE Slack's avatar
From EE Slack
Looking for advice, we’re building a MSM with 4 separate domains/sites, eventually it’ll be 4 different sites running of of one EE instance. So far so good without any hassle.
We’ve added a lot of partials and some variables that we want to use on all of these domains, but I believe this is impossible according to the docs, is my assumption (docs) correct or am i not using the correct syntax? I’ve tried embedding it.
I’m afraid we have to go a different route with these components / partials.. but i would like to steer away from using to many embeds as this could have performance implications when using to many.
What would be a good way to implement this partials/component library into EE? So we could re-use these components through all these domains? Should I go the template layout and embed route? Or maybe create a template.group just for these components?
Thanks in advance
Interested in learning more solutions or want to get to know other EE users? Read more about joining the slack here! Join Our Slack!
jelle's avatar
jelle
jelle's avatar jelle
If you go to cp/design/snippets/edit/ENTRY_ID you should see “Enable on all sites?” on the bottom of your screen
