CSS Not loading
News and General
Matahi's avatar
Matahi
Matahi's avatar Matahi
I have a problem with CSS loading. They work when the template is the index but not in the rest. I have checked all the paths and they are correct. I have also uploaded an html version of the pages and they work.
Any ideas?
lincolnpixel's avatar
lincolnpixel
lincolnpixel's avatar lincolnpixel
Hi Matahi,
              Can you share a little more of the code that you’re using ?
Matahi's avatar
Matahi
Hi, Lincolnpixel
This is the test-page i am working on:
https://sabbastudio.com/es/pagina
lincolnpixel
A quick look at the html source, can see that your custom css stylesheet
https://sabbastudio.com/index.php?css=css_styles/custom.v.1683972131
have the index.php
Are you removing index.php from urls?
Matahi's avatar
Matahi
Yes, I removed the index.php but the custom stylesheet is the same as the main stylesheet wich loads correctly. In fact, both of them load correctly but do not render.
lincolnpixel
Kindly share your template tag, at least the one you’re using for the stylesheet.
Matahi's avatar
Matahi
<link rel="stylesheet" href="/components/base/base.css">
lincolnpixel
While the one for the Custom Css?
Matahi's avatar
Matahi
The custom css is empty. I am getting multiple “The stylesheet was not loaded because its MIME type, “text/html” is not “text/css” errors in the developer console. But not when the same template is marked as the Index page.
