How to use Low Search or Low Variables with EE Pro - Invalid License Error
bree's avatar
bree
bree's avatar bree
I installed EE Pro which should come with the Low Variables and Low Search add-ons. But I cannot get past the Invalid License error to use them.
A slack post said with Pro the License should not be required, but it is for me.
Please advise. thanks.
Jason's avatar
Jason
3 years ago
Jason's avatar Jason
Hmmm…
I’m having the same issue. EE Pro accepts the license perfectly, but neither Low Variables nor Low Search seem to work with my paid Pro license.
I’ve tried uninstalling and reinstalling all 3 add-ons in various order. No joy.
Any fixes for this yet?
DracoDeans's avatar
DracoDeans
DracoDeans's avatar DracoDeans
Hi, If you’ve installed EE Pro and are encountering an “Invalid License” error when trying to use Low Variables and Low Search, you’ll need to make sure that your EE license is entered and valid. While the Pro version does come with these add-ons, it still requires a valid license for EE itself.
To check whether your EE license is valid, you can go to your ExpressionEngine control panel and navigate to the License & Support page. If you’re still having trouble, you can contact EllisLab support for further assistance.
