Errors when Uploading images in an entry
bbailey's avatar
bbailey
bbailey's avatar bbailey
I am having an issue with uploading images into an entry. I go through all the steps (the image actually gets uploaded to the server) but I get stuck with the following on the screen with no way to actually add the image to the entry.
{"file_id":57,"site_id":1,"title":"2.jpg","upload_location_id":16,"mime_type":"image\/jpeg","file_name":"2.jpg","file_size":138516,"description":"","credit":"","location":"","uploaded_by_member_id":1,"upload_date":1640831853,"modified_by_member_id":1,"modified_date":1640831853,"file_hw_original":"302 453","path":"https:\/\/www.domain-url.com\/images\/calendar\/2.jpg","thumb_path":"https:\/\/www.domain-url.com\/images\/calendar\/_thumbs\/2.jpg","isImage":true,"isSVG":false}
I recently changed my domain name but uploading images into an entry worked before I changed the domain name. Any ideas what could have happened with the domain change to cause this and how do I fix the problem?
Would you happen to have been doing some troubleshooting and added a die() , var_dump, etc statement anywhere in the core?
If not, I would start by checking out the dev tools Network tab in your browser while trying to upload and check all the responses from different calls that are made.
bbailey's avatar
bbailey
Andy, I haven’t been doing any troubleshooting in the core.
When I used the dev tools in my chrome browser I see the file where the error is coming from. Image Attached. Any further insight would be greatly appreciated.
