I need someone to fix my site
Rick Cosaro's avatar
Rick Cosaro
Rick Cosaro's avatar Rick Cosaro
My site is currently running EE 2.9.2, and I have a sub-domain that’s just showing a white screen. I changed the PHP back to 7.0, but it’s still not working.
Wessel's avatar
Wessel
Wessel's avatar Wessel
Hi Rick,
EE 2.9.2 won’t work at PHP 7 or later versions. Try so set back to 5.6 and I think your problem will be solved.
Kind regards,
W
Rick Cosaro
Thanks, that worked. Now I just need to find someone to upgrade my site to the latest EE version.
Wessel's avatar
Wessel
To be quite honest, from 2.9.2 to 6 is a serious job because of addons, database structure etcetera. I’ll send you a DM by Linkedin.
