Fluid field support for 3rd party fieldtypes
Feature Requests
James Catt's avatar
James Catt
8 years ago
James Catt's avatar James Catt
I realize this may be complicated, and might require plugin vendors to modify their fieldtypes for compatibility, but I’d really like to see Fluid fields support 3rd party fieldtypes.
In particular, I was hoping to be able to use Wygwam in a Fluid field, but it appears this is only currently possible by embedding the Wygwam field in a Grid field (and then the Grid field in the Fluid field).
Jeremy S.'s avatar
Jeremy S.
8 years ago
Jeremy S.'s avatar Jeremy S.
It’s the other way around. 3rd party fields types (add-ons) must support fluid fields. It’s up to the add-on developer. You’ll have to speak with eeHarbour in this case.
James Catt's avatar
James Catt
8 years ago
Ah yes, it looks like WYGWAM does support it, there was just a bug which they’ve now fixed.
The docs might need a tweak though, since they actually say “A Fluid field can contain any native field type…”
