This is the error I get:
Exception Caught
SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘exp_channels.channel_idLEFT’ in ‘on clause’: SELECT t.entry_id , exp_channels.channel_id FROM exp_channel_titles AS t LEFT JOIN exp_channels ON t.channel_id = exp_channels.channel_idLEFT JOIN exp_members AS m ON m.member_id = t.author_id WHERE t.entry_id !=” AND t.site_id IN (‘1’) AND t.entry_date < 1511322261 AND (t.expiration_date = 0 OR t.expiration_date > 1511322261) AND m.member_id = ‘1’AND t.status = ‘open’ ORDER BY t.sticky desc, t.entry_date desc, t.entry_id desc LIMIT 0, 15
ee/legacy/database/drivers/mysqli/mysqli_connection.php:116
Can be reproduced with this simple code:
<ul>
{ exp:channel:entries author_id="1" limit="15"}
<li>Error when using 'author_id' parameter in 'exp:channel:entries' tag</li>
{ /exp:channel:entries}
</ul>
It appears to be due to how you are trying to add a join on exp_members and it’s triggered by part of the pagination routine on line 2187 of mod.channel.php.
Not sure if this was supposed to be fixed in RC 1, but I noticed it’s fixed when there’s no pagination, but the issue persists with a different error when there is pagination.
Exception Caught
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'm.member_id' in 'where clause':
SELECT t.entry_id , exp_channels.channel_id FROM exp_channel_titles AS t LEFT JOIN exp_channels ON t.channel_id = exp_channels.channel_id WHERE t.entry_id !='' AND t.site_id IN ('1') AND t.entry_date < 1511420957 AND (t.expiration_date = 0 OR t.expiration_date > 1511420957) AND m.member_id = '1'AND t.status = 'open'
