How to determine if a new fluid field is a fluid field in display_field
November 15, 2017 3:48pm
  • #1 / Nov 15, 2017 3:48pm
    Reinos
    As the title say, how can i determine if I deal with a fluid field. Especially new fields, because on existing fields there is a variable available “$this->settings[‘fluid_field_data_id’]”.
  • #2 / Nov 15, 2017 4:07pm
    Kevin Cupp's avatar
    Kevin Cupp
    If you check $this->content_type(), does it return fluid_field?
  • #3 / Nov 15, 2017 4:14pm
    Reinos
    That returned channel inside the display_field() method
  • #4 / Nov 15, 2017 4:15pm
    Kevin Cupp's avatar
    Kevin Cupp
    Ah ok, I’m not sure we can change that either since Fluid technically works with Channel fields. Lemme volley this over to Seth.
  • #5 / Nov 15, 2017 4:26pm
    Seth Barber's avatar
    Seth Barber
    In system/ee/EllisLab/Addons/fluid_field/ft.fluid_field.php change lines 579 to 582 to just:
    $field->setItem('fluid_field_data_id', $fluid_field_data_id);
    Let me know if that works.
  • #6 / Nov 16, 2017 1:46pm
    Reinos
    Hi Seth,
    That does not work. On adding a new field the variable fluid_field_data_id still does not exists.
  • #7 / Nov 16, 2017 2:03pm
    Seth Barber
    It should exist, but be set to NULL. How are you testing it’s existence? You should be able to do array_key_exists('fluid_field_data_id', $this->settings).
  • #8 / Nov 16, 2017 2:03pm
    Seth Barber
  • #9 / Nov 16, 2017 3:50pm
    Reinos
    Hi Seth,
    I test it now by just dumping var_dump($this->settings); the settings array. But with the possible fix you suggest, the key is not in the settings array. When the field exists, the key is in the settings table.
  • #10 / Nov 17, 2017 11:58am
    Seth Barber
    Try adding $f->setItem('fluid_field_data_id', NULL); at line 349 of system/ee/EllisLab/Addons/fluid_field/ft.fluid_field.php and see if that resolves it.
  • #11 / Nov 21, 2017 3:12pm
    Reinos
    Hi Seth,
    saw you pushed it already on the new build 😉 Also here the confirmation it worked!
ExpressionEngine News
