When I generate a form field like so:
$sections[0][] = array(
'title' => 'set_label',
'desc' => 'set_label_help',
'fields' => array(
'set_id' => array(
'type' => 'hidden',
'value' => $set_id
'set_label' => array(
'required' => TRUE,
'type' => 'text',
'value' => $set['set_label']
…I get a div.add-mrg-top
around the second input field, resulting in unnecessary spacing. The div shouldn’t be added when there’s hidden fields there.
Confirmed and fixed, thanks Low, the next build will only add that margin for visible sequential fields. If you want to patch yours up now so you can be sure your forms are rendering properly, open system/ee/EllisLab/ExpressionEngine/View/_shared/form/fieldset.php
and replace the $count++
on line 130 with:
if ($field['type'] != 'hidden')
$count++;
