When visiting a LV CP page containing a Grid field, I get this error message:
Exception Caught
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'fluid_field_data_id' in 'where clause':
SELECT * FROM (`exp_low_variables_grid_field_104`) WHERE `entry_id` IN (104) AND `fluid_field_data_id` = 0 ORDER BY `row_order` asc
ee/legacy/database/drivers/mysqli/mysqli_connection.php:116
Stack Trace: Please include when reporting this error
#0 ee/legacy/database/drivers/mysqli/mysqli_driver.php(111): CI_DB_mysqli_connection->query('SELECT *\nFROM (...')
#1 ee/legacy/database/DB_driver.php(269): CI_DB_mysqli_driver->_execute('SELECT *\nFROM (...')
#2 ee/legacy/database/DB_driver.php(179): CI_DB_driver->simple_query('SELECT *\nFROM (...')
#3 ee/legacy/database/DB_active_rec.php(1137): CI_DB_driver->query('SELECT *\nFROM (...')
#4 ee/legacy/models/grid_model.php(436): CI_DB_active_record->get('low_variables_g...')
#5 ee/EllisLab/Addons/grid/libraries/Grid_lib.php(60): Grid_model->get_entry_rows(Array, 104, 'low_variables', Array, false, 0)
#6 ee/EllisLab/Addons/grid/ft.grid.php(137): Grid_lib->display_field(Object(EllisLab\ExpressionEngine\Library\CP\GridInput), ' ')
#7 /Users/low/Software/low_variables/low_variables/types/type.low_variables.php(186): Grid_ft->display_field(' ')
#8 /Users/low/Software/low_variables/low_variables/types/low_grid/vt.low_grid.php(96): Low_variables_type->call_ft('display_field', ' ')
#9 /Users/low/Software/low_variables/low_variables/mcp.low_variables.php(258): Low_grid->display_field(' ')
#10 [internal function]: Low_variables_mcp->group('6')
#11 ee/EllisLab/ExpressionEngine/Controller/Addons/Addons.php(1609): call_user_func_array(Array, Array)
#12 ee/EllisLab/ExpressionEngine/Controller/Addons/Addons.php(893): EllisLab\ExpressionEngine\Controller\Addons\Addons->getModuleSettings('low_variables', 'group', Array)
#13 [internal function]: EllisLab\ExpressionEngine\Controller\Addons\Addons->settings('low_variables', 'group', '6')
#14 ee/EllisLab/ExpressionEngine/Core/Core.php(229): call_user_func_array(Array, Array)
#15 ee/EllisLab/ExpressionEngine/Core/Core.php(109): EllisLab\ExpressionEngine\Core\Core->runController(Array)
#16 ee/EllisLab/ExpressionEngine/Boot/boot.php(146): EllisLab\ExpressionEngine\Core\Core->run(Object(EllisLab\ExpressionEngine\Core\Request))
#17 admin.php(147): require_once('...')
LV calls the Grid field type, which (by the looks of it) tries to include a fluid field id, which doesn’t exist in the low_variables_grid_field_x tables.
Looks like the updater doesn’t update 3rd party content types’ Grid fields. Is that a bug, or is that up to the 3rd party dev?
Hi Low,
We only add the fluid_field_data_id
column to the Relationships table and all our Grid field tables since they store their field data separately, and we need a way to mark the data is inside a Fluid Field. Looking at copy of Low Variables (v3.0.4) it looks like you are instantiating your own copy of the Grid fieldtype and storing data in your own table. I’ve been trying to come up with a way to detect this kind of usage during our update so we could add this column to your tables, but I’m not coming up with anything right now. If you have a way our app could find your grid tables I’d be happy to add this column during the 4.0 update, otherwise, you will have to add it in your add-on’s update routine.
Well, the Grid field itself generates the exp_[content-type]_grid_field_x
tables. So I guess you could query the exp_content_types
table, then check for all existing exp_[content-types]_grid_field_x
tables to see if the fluid_field_data_id
is present, and add it if necessary. Since Low Variables itself doesn’t generate Grid’s tables, I would assume Grid would take care of its own compatibility here.
