Dear Support, I just ran a local upgrade of EE from 2.8.1 to 3.5.11. The upgrade succeeded although I’ve noticed for one of my custom channels, when I go to enter or edit an entry in the Control Panel, the theme won’t load, causing the page to render without styling. Also, upon saving the entry, this exception is thrown:
Exception Caught
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘surly_dev.exp_channel_grid_field_2’ doesn’t exist:
SELECT * FROM (exp_channel_grid_field_2
) WHERE entry_id
= 16621
ee/legacy/database/drivers/mysqli/mysqli_connection.php:122
Stack Trace: hide details
#0 ee/legacy/database/drivers/mysqli/mysqli_driver.php(137): CI_DB_mysqli_connection->query(‘SELECT *\nFROM (…’)
#1 ee/legacy/database/DB_driver.php(297): CI_DB_mysqli_driver->_execute(‘SELECT *\nFROM (…’)
#2 ee/legacy/database/DB_driver.php(203): CI_DB_driver->simple_query(‘SELECT *\nFROM (…’)
#3 ee/legacy/database/DB_active_rec.php(1219): CI_DB_driver->query(‘SELECT *\nFROM (…’)
#4 ee/legacy/models/grid_model.php(356): CI_DB_active_record->get(‘channel_grid_fi…’)
#5 ee/EllisLab/Addons/grid/libraries/Grid_lib.php(246): Grid_model->get_entry(16621, 6, ‘channel’)
#6 ee/EllisLab/Addons/grid/ft.grid.php(64): Grid_lib->validate(NULL)
#7 [internal function]: Grid_ft->validate(NULL)
#8 ee/legacy/libraries/api/Api_channel_fields.php(409): call_user_func_array(Array, Array)
#9 ee/EllisLab/ExpressionEngine/Model/Content/FieldFacade.php(158): Api_channel_fields->apply(‘validate’, Array)
#10 ee/EllisLab/ExpressionEngine/Model/Content/ContentModel.php(274): EllisLab\ExpressionEngine\Model\Content\FieldFacade->validate(NULL)
#11 ee/EllisLab/ExpressionEngine/Service/Validation/Validator.php(262): EllisLab\ExpressionEngine\Model\Content\ContentModel->validateCustomField(‘field_id_6’, NULL, Array, Object(EllisLab\ExpressionEngine\Service\Validation\Rule\Callback))
#12 [internal function]: EllisLab\ExpressionEngine\Service\Validation\Validator->EllisLab\ExpressionEngine\Service\Validation{closure}(‘field_id_6’, NULL, Array, Object(EllisLab\ExpressionEngine\Service\Validation\Rule\Callback))
#13 ee/EllisLab/ExpressionEngine/Service/Validation/Rule/Callback.php(42): call_user_func(Object(Closure), ‘field_id_6’, NULL, Array, Object(EllisLab\ExpressionEngine\Service\Validation\Rule\Callback))
#14 ee/EllisLab/ExpressionEngine/Service/Validation/Validator.php(198): EllisLab\ExpressionEngine\Service\Validation\Rule\Callback->validate(‘field_id_6’, NULL)
#15 ee/EllisLab/ExpressionEngine/Service/Validation/Validator.php(159): EllisLab\ExpressionEngine\Service\Validation\Validator->_validate(Object(EllisLab\ExpressionEngine\Model\Channel\ChannelEntry), true)
#16 ee/EllisLab/ExpressionEngine/Service/Model/Model.php(484): EllisLab\ExpressionEngine\Service\Validation\Validator->validatePartial(Object(EllisLab\ExpressionEngine\Model\Channel\ChannelEntry))
#17 ee/EllisLab/ExpressionEngine/Model/Channel/ChannelEntry.php(174): EllisLab\ExpressionEngine\Service\Model\Model->validate()
#18 ee/EllisLab/ExpressionEngine/Controller/Publish/AbstractPublish.php(272): EllisLab\ExpressionEngine\Model\Channel\ChannelEntry->validate()
#19 ee/EllisLab/ExpressionEngine/Controller/Publish/Edit.php(475): EllisLab\ExpressionEngine\Controller\Publish\AbstractPublish->validateEntry(Object(EllisLab\ExpressionEngine\Model\Channel\ChannelEntry), Object(EllisLab\ExpressionEngine\Model\Content\Display\LayoutDisplay))
#20 [internal function]: EllisLab\ExpressionEngine\Controller\Publish\Edit->entry(‘16621’)
#21 ee/EllisLab/ExpressionEngine/Core/Core.php(189): call_user_func_array(Array, Array)
#22 ee/EllisLab/ExpressionEngine/Core/Core.php(94): EllisLab\ExpressionEngine\Core\Core->runController(Array)
#23 ee/EllisLab/ExpressionEngine/Boot/boot.php(151): EllisLab\ExpressionEngine\Core\Core->run(Object(EllisLab\ExpressionEngine\Core\Request))
#24 admin.php(143): require_once(‘…’)
The table, ‘exp_channel_grid_field_2’, mentioned above does not exist in the database (pre- or post upgrade). Also, I’ve checked the Settings, and the Themes folder is correctly pointed to.
Any recommendations on how to fix greatly appreciated.
Best, Louise
Hi Louise,
We can’t offer official support in the forums; you’re welcome to get help from the community here or in Slack, but for us to diagnose or fix the problem you are having, you will need to put in a support ticket to get assistance from one of our engineers. Thanks!
