Mail Not Sending
mr_ripley's avatar
mr_ripley
about 10 years ago
mr_ripley's avatar mr_ripley
When I use the Communicate button, I get the error: Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 65488 bytes) in D:\home\site\wwwroot\system\expressionengine\core\EE_Exceptions.php on line 352
Nothing has changed. It was working, now it is not.
Also, I have Freedom Form Pro installed. It registers in the CP that an email has been sent but it does not send out the admin notification.
I’m using sendgrid and have all of the correct settings.
EE version: v2.10.1 Freedom Form vs 4
Derek Jones's avatar
Derek Jones
about 10 years ago
The Communicate page and email send are pretty low-memory operations, so something is definitely awry. How many recipients are you sending to, are you using “batch” mode, and what version of PHP is on this server?
mr_ripley's avatar
mr_ripley
about 10 years ago
PHP Version 5.4.45
Batch mode = I have tried it on and off. Recipients = 1 - just a test message.
For some reason I have seen this error message before and have to duplicate entries so I can edit them.
Also, I’m using sendgrid, SMTP
Derek Jones
about 10 years ago
What extensions do you have installed? None of those operations should be using anywhere near that memory. Methinks you may have some non-native operations going on in the background.
mr_ripley's avatar
mr_ripley
about 10 years ago
I posted an image of my extensions.
Derek Jones
about 10 years ago
Er… where? 😉
mr_ripley's avatar
mr_ripley
about 10 years ago
These are my extensions
Derek Jones
about 10 years ago
So I have an idea of what might be causing your memory issues, but someone on our team would need to log in directly to debug. If you’d like us to do that, please put in a support ticket and provide log in access (credentials are encrypted in the support portal and auto-destroyed after 30 days).
mr_ripley's avatar
mr_ripley
about 10 years ago
Thanks. I opened a ticket.
about 10 years ago
Just circling back in case anyone runs into something similar.
The memory error was very very odd! It ended up being the result of some commented out code where the system error message codes/text are specified. The 500 error was commented out, resulting in any system error that returned a 500 code triggering an infinite loop and thus running out of memory.
Restoring the commented out bit got errors working- and the resulting email debug points to the mail server not authenticating the smtp connection data.
Glad you brought it to support- that one needed some code digging to spot!
