ExpressionEngine 3.1.1 Released
News and General
Wes Baker's avatar
Wes Baker
10 years ago
Wes Baker's avatar Wes Baker
Only two days after 3.1.0 was released, we’re releasing 3.1.1. We found a few bugs that we couldn’t let stand and squashed them as fast as possible. It’s releases like this that make us really thankful for 3.0’s much-improved updater.
In particular, there were a few PHP errors thrown when creating template groups when saving templates as files, when sometimes submitting a contact form, and when some add-ons would save particular models. With these bugs, you can expect our test coverage to increase in those areas as well to help ensure they never come up again.
As usual, you can download the latest version of ExpressionEngine from your Manage Your Purchases page and read the changelog over in the user guide.
Jürgen's avatar
Jürgen
10 years ago
Jürgen's avatar Jürgen
MMh,
it seems that there is still something to do….
Ingmar's avatar
10 years ago
Ingmar's avatar Ingmar
Are you sure that permissions are in order?
James Mathias's avatar
James Mathias
10 years ago
James Mathias's avatar James Mathias
MMh, it seems that there is still something to do….
This is a bug, we are working on a fix.
In fact if you want you can patch this. In the file “system/ee/installer/updates/ud_3_01_00.php”
Find this line ~235
if ( ! rename($avatar_path.'/'.$filename, $avatar_path.'/default/'.$filename))
And change it to
if (file_exists($avatar_path.'/'.$filename)
Then make sure your config file shows version 3.0.6. Then go back to the updater and let it run from 3.0.6 to 3.1.1 Should fix the problem.
Jürgen's avatar
Jürgen
10 years ago
Thank you, looks better now.
If have still many more problems directly after upgrading from version 2.0, e.g. calliing “My Profile” ends in:
Attempting to access file outside of directory.
…./system/ee/EllisLab/ExpressionEngine/Service/File/Directory.php:28
or missing Lanuage parts… (see Screenshots)
and Plugins are not running because of missing EXT-Constant:
Notice..
Use of undefined constant EXT - assumed ‘EXT’
user/addons/navee/ft.navee.php, line 22 hide details
Severity: E_NOTICE
Where could I post these errors to?
Jeremy S.'s avatar
Jeremy S.
10 years ago
Jeremy S.'s avatar Jeremy S.
Since it looks like the issue is with the NavEE third party addon, best best is to check with the developer: https://fromtheoutfit.com/navee
Duncan McCall's avatar
Duncan McCall
10 years ago
Duncan McCall's avatar Duncan McCall
Just did my first clean install of v3 (3.1.2) with no third-party anything. When I go to the Add On Manager, I get a whole list of errors and warnings starting with:
Error
Argument 1 passed to EllisLab\ExpressionEngine\Service\Addon\Addon::requireFieldtypes() must be an array, boolean given, called in /PATHTOSYSTEM/ee/EllisLab/ExpressionEngine/Service/Addon/Addon.php on line 384 and defined
ee/EllisLab/ExpressionEngine/Service/Addon/Addon.php, line 439
I get a similar list of errors when trying to create a new field in a field group. But it seems to still work.
Seth Barber's avatar
Seth Barber
10 years ago
Seth Barber's avatar Seth Barber
Bryan,
Looks like a call to glob is returning FALSE, which they note is the return if there is an error. It’s possible that PHP is not able to read a file and/or directory and is thus returning an error. Have you checked the permissions of your addons folder and subfolders?
Duncan McCall
10 years ago
Permissions are 755. But thanks for the feedback, maybe it’s a direction.
Seth Barber
10 years ago
Bryan,
In system/ee/EllisLab/ExpressionEngine/Service/Addon/Addon.php you can try adding
print_r(error_get_last());
at line 396 (before the requireFieldtypes call). That might give you a clue as to why the error is happening.
Duncan McCall
10 years ago
That did not give any error at that point.
Seth Barber
10 years ago
Bryan,
In system/ee/EllisLab/ExpressionEngine/Service/Addon/Addon.php try replacing the getFilesMatching() method (arund line 427) with:
protected function getFilesMatching($glob)
    return (glob($this->getPath()."/{$glob}")) ?: array();
That should resolve the error message you are getting.
Derek Jones's avatar
Derek Jones
10 years ago
Bryan, can you also check to see if you have any empty folders on the remote server in either system/ee/EllisLab/Addons or system/user/Addons?
Duncan McCall
10 years ago
The code edit fixed the problem.
I did look for empty folders and there were none.
Thanks for your help.
