EE 3.1: Using Model::fill() on existing item and saving
Developer Preview
Manuel Payano's avatar
Manuel Payano
10 years ago
Manuel Payano's avatar Manuel Payano
If you have an existing model object, you can use Model::fill() to quickly set a bunch of properties. (setters are skipped).
But if you use Model::save() on the object, none of the dirty properties are saved, they are simply ignored.
When saving, it seems that no dirty properties are found.
Example Code
$form = ee('Model')->get('forms:Form', $form_id)->first();
$form->fill($postData);
$form->save(); // Nothing is saved
foreach ($postData as $key => $val) {
    $form->setProperty($key, $val);
    $form->{$key} = $val;  // Same Thing
$form->save(); // Works as expected
Is this the expected behavior? Is there another way?
Manuel Payano
10 years ago
After some further digging i found the answer.
Entity::set() does the job also.
$form->set($postData);
Pascal Kriete's avatar
Pascal Kriete
10 years ago
Pascal Kriete's avatar Pascal Kriete
Looks like you found it! For reference, fill is what we use to hydrate the model from the db.
