Hoping someone can help.
I am using AJW export to generate a CSV file that I can use to populate a store.
It is generating the file, but I can’t seem to get it to spit out the image url, or the category. AND it is including way more info than I need. The product title, description, price, and photo (with url to image) and category is the only information required.
Any ideas are appreciated.
{exp:ajw_export
sql="SELECT category, title, product_description, product_price, product_photo"
channel="products"
format="csv"
delimter=":"
filename="shop.csv"
}Here is a link to the CSV file it is outputting for reference.
Thanks, in advance.
