Is there a cleaner way to conditionally show code in an entry loop if related entries or category assignments exist?
August 13, 2013 1:57pm
  • #1 / Aug 13, 2013 1:57pm
    jaasum
    I ran into what I imagine is a common use case and I know there has to be a cleaner way to do this.
    {exp:channel:entries channel="media" limit="1" dynamic="no" paginate="bottom"}
     <article class="mediaList">
      <h2><a href="http://{url_title_path=media/detail}">{title}</a></h2>
    <p>  <dl></p>
    <p>   {media-speaker limit="1"}<br />
       <dt>Speaker</dt><br />
       <dd><br />
       {/media-speaker}</p>
    <p>   {media-speaker backspace="10"}<br />
       {media-speaker:people-first} {media-speaker:people-last}, <br />
       </dd><br />
    <p>   {categories show_group="2" limit="1"}<br />
       <dt>Service</dt><br />
       <dd><br />
       {/categories}</p>
    <p>   {categories show_group="2" backspace="10"}<br />
       {category_name}, <br />
       {/categories}</p>
       </dd><br />
       {/categories}</p>
    <p>   {categories show_group="3" limit="1"}<br />
       <dt>Series</dt><br />
       <dd><br />
       {/categories}</p>
    <p>   {categories show_group="3" backspace="10"}<br />
       {/categories}</p>
       </dd><br />
       {/categories}</p>
    <p>  </dl><br />
      {media-description}<br />
      <a href="http://">View this entry.</a><br />
     </article><br />
     {paginate}<br />
            Page {current_page} of {total_pages} pages {pagination_links}<br />
        {/paginate}<br />
    In three places I’m forced to use the categories or related fields tag with a limit of 1 to show opening tags, closing tags, and headings. Is there an easier way to test “if related field” or “if category group # is assigned” instead of running multiple loops?
    I’m simply trying to have a list page that shows conditional meta information about each post (such as if speakers are assigned which sometimes may be multiple, if certain category groups and categories are assigned which are also sometimes multiples).
  • #2 / Aug 13, 2013 7:24pm
    Rob Allen
    You can use conditional to check the first and last item, eg:
    <dl>
    {media-speaker}
    {if media-speaker:count == "1"}
    <dt>Speaker</dt>
    <dd>{media-speaker:people-first} {media-speaker:people-last}</dd>
    {/media-speaker}
    </dl>
    That will add the DT on the first media-speaker loop, then add in all the DD’ for each occurrence. If there are no speakers the tag won’t output anything.
    Use the same logic for other fields…
  • #3 / Aug 13, 2013 7:50pm
    jaasum
    That would work well for the relationship field, however the category variable pair doesn’t have count available as far as I know.
  • #4 / Aug 14, 2013 4:00pm
    Rob Allen
    No count for categories (well not inside channel entries tag), but http://gwcode.com/add-ons/gwcode-categories addon will do it for you, you can assign it an entry_id and it will pump out assigned categories, and you can run a conditional inside the gwcats tag to pull in your DT in the first loop.
